QUESTIONS> master cylinder wires and directionals, >> 23oct - new question (SEE VIDEO) |
jimkelly |
Oct 22 2013, 01:34 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
what to do.
my directionals are not blinking and I think it is related. see post #7 http://www.914world.com/bbs2/index.php?sho...hl=directionals found my answer - brown/white gets hooked up to spade http://www.914world.com/bbs2/index.php?sho...+cylinder+wires Attached image(s) |
Mike Bellis |
Oct 22 2013, 01:49 PM
One of your brown wire has a white or yellow stripe. Connect this one. The other is just a ground.
bulitt |
Oct 22 2013, 01:51 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Darling Dave says- "The wires should be brown/white, and plain brown.
Plain brown is always ground in these cars. Always--unless some previous mechanic or owner started replacing wires. The original brake warning switch had two spade terminals on it. One of the two wires plugged into each of them. Some later switches only have the one terminal. The brown/white gets plugged into that; the ground is actually provided through the body of the master cylinder in those cases. The rubber cover is covering the reset button. You may find that the brake warning light starts blinking when you plug that wire in (and the key is on). Just push the button and the light should go out--if the handbrake is not on. Tape up the brown wire so it's out of the way. It can touch the chassis, because both the wire and the chassis are at ground. But don't cut it out because you may eventually replace the switch for the two-pin style somewhere down the road." |
jimkelly |
Oct 22 2013, 01:59 PM
right now I am waiting on 7.5 amp fuses to arrive for the first 4 slots in my fuse box, so they currently empty, so no headlights at the moment.
my parking lights all come on, and my hazards work/blink. but my directional lights comes on but stay on solid, no blinking. could be a relay on my fuse box? does ignition key need to be turned for directional to blink? a good bowlsby for thiose that have not yet stumbled upon it https://bowlsby.net/914/Classic/TechNotebook.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-2460-1382472318.1.jpg) |
bulitt |
Oct 22 2013, 03:45 PM
Jim- This flasher circuit was obviously designed by a very intelligent German fellow after way to many brewski's. Check this thread out. You may have a bad primary flasher relay.
Flasher secret decoder |
JeffBowlsby |
Oct 22 2013, 08:56 PM
914 Wiring Harnesses Group: Members Posts: 8,506 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You can always get the correct MC switch for your car. 1-pole or 2-pole, no monkey business.
jimkelly |
Oct 23 2013, 06:22 AM
ok - I thought that MAYBE my ignition key needed to be in and switched on, for directionals to flash and for brake lights to light when brake peddle is pushed.
so I connected battery, put key in and switched it on, and YES, directionals and brake lights both worked. >>> EXCEPT THAT when I popped headlights UP, only right directional would flash, driver side front light would stay lite but not flash. yet rear light blinks and dash lights blink (both arrows I think but this is an old problem) note: I do not have any fuses in first 4 fuse box slots, so headlights did not come on. I assume this could have effected directionals? https://www.youtube.com/watch?v=xqDC7yq6L24 Attached image(s) |
Tom |
Oct 23 2013, 01:11 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Jim,
Is your flasher/emergency relay clicking when the left side is selected? If the relay isn't clicking, the light won't change state, on/off. Maybe there is a wiring error between the turn signal stalk and the relay. You could temporarily use 10 amp fuses in those first 4 slots without causing any damage. You can but ATC type fuses at any parts store. Tom |
jimkelly |
Oct 23 2013, 01:18 PM
yes and the rear driver side light is blinking, just not front.
I assume the driver side front and rear lights are on same relay? jim |
Tom |
Oct 23 2013, 01:46 PM
That's good news. So the next place I would check is the wiring to the left turn signal and the sockets. Maybe compare them to the right side as to where the grounds and signal wires are hooked up. Front/rear are on same relay, so something is amiss in the left side front.
Tom |
toolguy |
Oct 23 2013, 01:59 PM
Remember about the Euro parking light circuit on all our cars. . If you have the key off and try the turn lights, they will light but not flash. . for parking on small streets at night as a warning light for other cars. .
I had a problem once when I put all new bulbs in the front outside fixtures. . the dash indicators would both blink at the same time, instead of just the side I was turning. . . but the outside lights worked correctly. . turned out it was caused by the outside bulb wattage being not exactly as what the factory prescribed. . . . once I put the old bulbs back it , everything worked correctly. . |
Lo-Fi Version | Time is now: 16th May 2024 - 12:12 AM |
