door sill valences |
arcadeforever |
Oct 27 2013, 03:04 PM
Member Group: Members Posts: 69 Joined: 25-October 13 From: United States Member No.: 16,568 Region Association: MidAtlantic Region |
Hi, yet another question, it appears my door sill valences, hopefully the right nomenclature, are plastic and say Porsche on them, are they after market, and should they be just solid metal?
thanks Wayne |
dlkawashima |
Oct 27 2013, 03:17 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Hi, yet another question, it appears my door sill valences, hopefully the right nomenclature, are plastic and say Porsche on them, are they after market, and should they be just solid metal? thanks Wayne I don't believe original door sill rails had "Porsche" on them. Whether your car should have aluminum or black plastic rails depends on the build date of your car. Threshold rails switched to black plastic mid-73 model year. |
arcadeforever |
Oct 27 2013, 03:26 PM
Hi, yet another question, it appears my door sill valences, hopefully the right nomenclature, are plastic and say Porsche on them, are they after market, and should they be just solid metal? thanks Wayne I don't believe original door sill rails had "Porsche" on them. Whether your car should have aluminum or black plastic rails depends on the build date of your car. Threshold rails switched to black plastic mid-73 model year. Oh, ok, mine is a '71 |
bcheney |
Oct 27 2013, 03:50 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Hi, yet another question, it appears my door sill valences, hopefully the right nomenclature, are plastic and say Porsche on them, are they after market, and should they be just solid metal? thanks Wayne I don't believe original door sill rails had "Porsche" on them. Whether your car should have aluminum or black plastic rails depends on the build date of your car. Threshold rails switched to black plastic mid-73 model year. The correct nomenclature for the part I think you are describing in "Rocker Panel". All OEM rocker panels where steel. You can buy fiberglass aftermarket rocker panels. I believe what you have are ABS plastic aftermarket rocker panels and they are (NLA) no longer available. If the PORSCHE script is offset from the center of the panel...that's what you have. Here is a picture. On this car they painted the raised lettering for effect. Attached image(s) |
arcadeforever |
Oct 27 2013, 04:46 PM
Hi, yet another question, it appears my door sill valences, hopefully the right nomenclature, are plastic and say Porsche on them, are they after market, and should they be just solid metal? thanks Wayne I don't believe original door sill rails had "Porsche" on them. Whether your car should have aluminum or black plastic rails depends on the build date of your car. Threshold rails switched to black plastic mid-73 model year. The correct nomenclature for the part I think you are describing in "Rocker Panel". All OEM rocker panels where steel. You can buy fiberglass aftermarket rocker panels. I believe what you have are ABS plastic aftermarket rocker panels and they are (NLA) no longer available. If the PORSCHE script is offset from the center of the panel...that's what you have. Here is a picture. On this car they painted the raised lettering for effect. Thanks very much, Rocker panel it is! mine are damaged, and Im looking at a set on CL for $100 now, is that a descent price? |
jimkelly |
Oct 27 2013, 04:58 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
yes
bcheney |
Oct 27 2013, 07:10 PM
Hi, yet another question, it appears my door sill valences, hopefully the right nomenclature, are plastic and say Porsche on them, are they after market, and should they be just solid metal? thanks Wayne I don't believe original door sill rails had "Porsche" on them. Whether your car should have aluminum or black plastic rails depends on the build date of your car. Threshold rails switched to black plastic mid-73 model year. The correct nomenclature for the part I think you are describing in "Rocker Panel". All OEM rocker panels where steel. You can buy fiberglass aftermarket rocker panels. I believe what you have are ABS plastic aftermarket rocker panels and they are (NLA) no longer available. If the PORSCHE script is offset from the center of the panel...that's what you have. Here is a picture. On this car they painted the raised lettering for effect. Great price depending on the condition you find them in. You want to be sure the mounting holes are in good shape. If they aren't...they could be hard to install and could end up looking bad as you do see them prominently whenever you open the door. Aftermarket new steel rocker panels go for $155 each and then you have to paint them. Here is a link to a supplier. http://www.restoration-design.com/mm5/merc...duct_Code=P300R |
Lo-Fi Version | Time is now: 16th May 2024 - 12:27 PM |
