Fuel gauge Ohm range, I 3D printed my own holder to fit the 911 dash pod! |
dfelz |
Nov 3 2013, 10:34 PM
beach bum Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California |
I need to buy one of the VDO fuel level gauges for the 914 and there are 3 Ohm range options. Who knows which one is the correct one for the stock sending unit?
Options: 0-90 10-180 73-10 Thanks! |
Mike Bellis |
Nov 3 2013, 10:57 PM
It's 0-70 ohm
The Chrysler is the closest but will read backwards. I once was able to flip the element in the sender and make it work well enough. |
dfelz |
Nov 4 2013, 11:22 AM
It's 0-70 ohm The Chrysler is the closest but will read backwards. I once was able to flip the element in the sender and make it work well enough. Thanks mike. I think I will just 3D print a new 80mm housing that will mount and display just the stock gauge level unit. Will actually be cheaper that buying a new VDO unit... To the drawing board! (IMG:style_emoticons/default/smash.gif) |
914forme |
Nov 4 2013, 12:44 PM
I run one (IMG:style_emoticons/default/confused24.gif)
VDO Fuel guage for VW sendors or CIP1 or VDO themselves Make it easy on yourself. |
dfelz |
Dec 12 2013, 02:14 PM
Well like i said, i went ahead and 3D printed my own holder, and am very happy with it! The lettering is difficult for the printer, and since the lid is a removable part i will continue to print other versions until i get one that looks the best. But for now, this will do!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1386879295.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1386879295.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1293.photobucket.com-14538-1386879296.3.jpg) |
ClayPerrine |
Dec 12 2013, 02:31 PM
Is this for a 911 style dash? If so, just use the 911 gauge. The 914 and the 911 use the same sender in the fuel tank, so it works perfectly.
Dec 12 2013, 05:14 PM
A suggestion...
Try not printing the letters at all, so leave a stencil of the letters there and backlight it with led lights...... Kinda like you cut out the lettering it what I am trying to say... |
dfelz |
Dec 13 2013, 07:17 PM
Clay, i do have a 911 fuel gauge, but i thought it looked funny with the oil level one just sitting there. I thought about putting a resistor on it to make it "look" like there was a reading but figured this would be more fun (IMG:style_emoticons/default/biggrin.gif) and the since the 911 gauge is a 911 gauge, its worth well more than what i spent printing this pod and using the stock unit.
r_towle, i contemplated that too, but the problem is the inside pieces, like inside the hole of the 9 and the 4.... my next lid will have just "914" in the same cursive style as above, but it will be much larger since porsche will not be above it, that should give me enough room to make the letters big enough to fully print and fill in. I also needed to widen the opening to better see the orange dial and the low level warning light. |
worn |
Dec 13 2013, 07:36 PM
can't remember Group: Members Posts: 3,155 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I need to buy one of the VDO fuel level gauges for the 914 and there are 3 Ohm range options. Who knows which one is the correct one for the stock sending unit? Options: 0-90 10-180 73-10 Thanks! I read the lower posts and have to admit i cannot understand the goal. I see you have made a mask for a fuel gauge, but why i cannot tell. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) |
worn |
Dec 13 2013, 07:37 PM
I need to buy one of the VDO fuel level gauges for the 914 and there are 3 Ohm range options. Who knows which one is the correct one for the stock sending unit? Options: 0-90 10-180 73-10 Thanks! I read the lower posts and have to admit i cannot understand the goal. I see you have made a mask for a fuel gauge, but why i cannot tell. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) I never hit no sawzall thingy. Swear it. (IMG:style_emoticons/default/santa_smiley.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/beerchug.gif) |
'73-914kid |
Dec 13 2013, 08:50 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
David bought a set of late 911 gauges for his Getty dash. Late 911 fuel senders differ from the 914/early 911 style sender, so the gauge would always read wrong. Rather then spend the money on an earlier 911 fuel gauge, he made his own housing for the 914 gauge instert. Seems like a more affordable and cool way to try out the 3d printing IMO.
ClayPerrine |
Dec 14 2013, 08:40 AM
Clay, i do have a 911 fuel gauge, but i thought it looked funny with the oil level one just sitting there. I thought about putting a resistor on it to make it "look" like there was a reading but figured this would be more fun (IMG:style_emoticons/default/biggrin.gif) and the since the 911 gauge is a 911 gauge, its worth well more than what i spent printing this pod and using the stock unit. r_towle, i contemplated that too, but the problem is the inside pieces, like inside the hole of the 9 and the 4.... my next lid will have just "914" in the same cursive style as above, but it will be much larger since porsche will not be above it, that should give me enough room to make the letters big enough to fully print and fill in. I also needed to widen the opening to better see the orange dial and the low level warning light. I have the same dash in my /6 conversion. I had the oil level gauge replaced with a volt meter. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.nhspeedometer.com-1143-1387032037.1.jpg) That is the only picture I could find real fast. North Hollywood Speedometer can do one in black too. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:33 PM |
