FS: G&R All 914 Rusty Whatchamacallit Pre-Sale List, Call dibs now... |
Eric_Shea |
Nov 4 2013, 07:16 PM
Here's a pre swap pre-sale list. Dig in. (IMG:style_emoticons/default/wink.gif)
PORTERFIELD AP30 $59.95 (no shipping saves 20%) PORTERFIELD AP31 $59.95 (no shipping saves 20%) PORTERFIELD AP31T $59.95 (no shipping saves 20%) PORTERFIELD AP45 $69.95 (no shipping saves 20%) PORTERFIELD AP45T $69.95 (no shipping saves 20%) PORTERFIELD AP288 $59.95 (no shipping saves 20%) PORTERFIELD AP287 $69.95 (no shipping saves 20%) Pagid T4114 $39.95 901.355.621.622 Hard line to rear caliper 914 OM Steel (Pair) $29.95 914.355.603.00OM Front caliper Fluid Inlet early $19.95 914.355.603.00SS Front caliper Fluid Inlet early Stainless $29.95 914.355.603.00G Front caliper Fluid Inlet early Green $39.95 Soft Lines 211.611.775B $14.50 Soft Lines 901.355.632.01 $14.50 Soft Lines 281.611.775B $14.50 Speed Bleeder SB7100 $12.00 Speed Bleeder SB8125LL $12.00 Speed Bleeder SB8125L $12.00 NEW Thru Body sway bar mount plates (Pair) $19.95 NEW ITEM 914.355.099.00 OC BrakeBrace 914 $69.95 NEW ITEM 911.355.099.00 OC BrakeBrace 911 $69.95 ATE Type 200 Brake Fluid $16.95 NEW 10x1 Bleeders $3.00 VB911R Alloy Rear Caliper for 911 Pair $699.00 VB914-6GT Alloy Rear Calipers Pair $899.00 VB914-6 Alloy Rear Calipers Pair $799.00 100mm Cap w/Fin $100.00 Type 3 Side Marker Lights Pair $40.00 DuroAno S-Caliper Pistons $40.00 each 5 lug Hubs (Conversion) for 914 Pair $115.00 914 Outer Suspension Mounts Powder Coated Pair $10.00 914 Outer Suspension Mount Powder Coated (Solo) $5.00 **Original 914-6 Rear Calipers (Pair) $1,200.00** L-Caliper (SWB 911 rears) B-Stock (Pair) $75.00 Early 914 Rear Caliper B-Stock (Pair) $149.00 1969 911 Rear or 914 rear race caliper (38mm pistons, larger pad, no handbrake) (Pair) $99.00 Early 914 front caliper B-Stock (Pair) $149.00 911 Bilstein Strut Restored (Single) $150.00 Strut top mount Bead Blasted $5.00 Early bearing Cap Plated $5.00 Pedal cluster clutch tube Plated $5.00 Front Brake Dust Shield Plated (911 M-Caliper/914-6) (Pair) $10.00 914 AL Threshold Door Plates New Anodizing (Pair) $25.00 Vacuum advance unit for Bosch 6 $10.00 Sway Bar Mounting tab Plated $5.00 911 Hand Brake Cable Mount $2.00 914 Late Model Door Glass Slider Plated (Pair) $5.00 911 Hand Brake Cable Tube Plated (Pair) $5.00 914 Master Cylinder Fluid Inlet Pipes Plated (Pair) $5.00 |
Lo-Fi Version | Time is now: 15th May 2024 - 05:12 AM |
