Here's a pre swap pre-sale list. Dig in.
PORTERFIELD AP30 $59.95 (no shipping saves 20%)
PORTERFIELD AP31 $59.95 (no shipping saves 20%)
PORTERFIELD AP31T $59.95 (no shipping saves 20%)
PORTERFIELD AP45 $69.95 (no shipping saves 20%)
PORTERFIELD AP45T $69.95 (no shipping saves 20%)
PORTERFIELD AP288 $59.95 (no shipping saves 20%)
PORTERFIELD AP287 $69.95 (no shipping saves 20%)
Pagid T4114 $39.95
901.355.621.622 Hard line to rear caliper 914 OM Steel (Pair) $29.95
914.355.603.00OM Front caliper Fluid Inlet early $19.95
914.355.603.00SS Front caliper Fluid Inlet early Stainless $29.95
914.355.603.00G Front caliper Fluid Inlet early Green $39.95
Soft Lines 211.611.775B $14.50
Soft Lines 901.355.632.01 $14.50
Soft Lines 281.611.775B $14.50
Speed Bleeder SB7100 $12.00
Speed Bleeder SB8125LL $12.00
Speed Bleeder SB8125L $12.00
NEW Thru Body sway bar mount plates (Pair) $19.95
NEW ITEM 914.355.099.00 OC BrakeBrace 914 $69.95
NEW ITEM 911.355.099.00 OC BrakeBrace 911 $69.95
ATE Type 200 Brake Fluid $16.95
NEW 10x1 Bleeders $3.00
VB911R Alloy Rear Caliper for 911 Pair $699.00
VB914-6GT Alloy Rear Calipers Pair $899.00
VB914-6 Alloy Rear Calipers Pair $799.00
100mm Cap w/Fin $100.00
Type 3 Side Marker Lights Pair $40.00
DuroAno S-Caliper Pistons $40.00 each
5 lug Hubs (Conversion) for 914 Pair $115.00
914 Outer Suspension Mounts Powder Coated Pair $10.00
914 Outer Suspension Mount Powder Coated (Solo) $5.00
**Original 914-6 Rear Calipers (Pair) $1,200.00**
L-Caliper (SWB 911 rears) B-Stock (Pair) $75.00
Early 914 Rear Caliper B-Stock (Pair) $149.00
1969 911 Rear or 914 rear race caliper (38mm pistons, larger pad, no handbrake) (Pair) $99.00
Early 914 front caliper B-Stock (Pair) $149.00
911 Bilstein Strut Restored (Single) $150.00
Strut top mount Bead Blasted $5.00
Early bearing Cap Plated $5.00
Pedal cluster clutch tube Plated $5.00
Front Brake Dust Shield Plated (911 M-Caliper/914-6) (Pair) $10.00
914 AL Threshold Door Plates New Anodizing (Pair) $25.00
Vacuum advance unit for Bosch 6 $10.00
Sway Bar Mounting tab Plated $5.00
911 Hand Brake Cable Mount $2.00
914 Late Model Door Glass Slider Plated (Pair) $5.00
911 Hand Brake Cable Tube Plated (Pair) $5.00
914 Master Cylinder Fluid Inlet Pipes Plated (Pair) $5.00
