Run on when shutting off, just started |
KaptKaos |
Dec 22 2004, 11:26 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
My 73 1.7 is starting to run on a bit when I shut her off. Any ideas where I should look first? Valves were adjusted about 2k miles ago, newish coil and most distributor parts are less than 2 years old.
Ideas? Thanks, Joe |
Brad Roberts |
Dec 23 2004, 12:14 AM
Check the timing. Did you change gas stations ? I know that Ca. likes to slip in "Winter gas" around this time every year.
Maybe Sammy will chime in. B |
KaptKaos |
Dec 23 2004, 11:25 AM
Thanks Brad. Yeah, my regular station is digging up its tanks or some other ridiculous process. Had to use a different station. Seems to run fine otherwise. I'll try and check the timing this weekend. Merry Christmas all. - Joe |
Lo-Fi Version | Time is now: 17th May 2024 - 05:18 PM |
