My 73 1.7 is starting to run on a bit when I shut her off. Any ideas where I should look first? Valves were adjusted about 2k miles ago, newish coil and most distributor parts are less than 2 years old.
Ideas?
Thanks,
Joe
QUOTE (Brad Roberts @ Dec 22 2004, 10:14 PM) |
Check the timing. Did you change gas stations ? I know that Ca. likes to slip in "Winter gas" around this time every year. Maybe Sammy will chime in. B |
