Plastic or metal air filter for 914-6? |
nmorrm |
Nov 6 2013, 12:45 AM
One square Group: Members Posts: 5 Joined: 11-February 05 From: Arcadia, CA Member No.: 3,586 Region Association: None |
Does anyone have the definitive answer to this query? My 71 914-6 has a plastic cover for the air filter. I am wondering if it was originally metal and swapped with a later plastic. Please let me know.
Thanks |
Mark Henry |
Nov 6 2013, 06:36 AM
I'm not 100% but I'm pretty sure the 914/6 came with the plastic air filter housing. Problem with the plastic is it can warp so they often were replaced with steel.
914itis |
Nov 6 2013, 06:41 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
thread hijack (IMG:style_emoticons/default/flag.gif)
Is there an advantage to use the air box? does it help with the carbs noise? |
Mark Henry |
Nov 6 2013, 08:59 AM
thread hijack (IMG:style_emoticons/default/flag.gif) Is there an advantage to use the air box? does it help with the carbs noise? It's a bit subjective as to if it adds/decreases power, but yes it does help a bit with noise. I believe with a 911 box you have to trim the snorkel and for performance most cut it off almost completely. I have the bottom bits for the webers so I'd like to try a box, but I think it's best just to get mine running (with the K&N and hats) first. (IMG:style_emoticons/default/smile.gif) |
mepstein |
Nov 6 2013, 09:01 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
plastic for a 914-6
Pat Garvey |
Nov 6 2013, 05:26 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
Can we uneducated non-six owners see a pic of the part?
1970 Neun vierzehn |
Nov 6 2013, 07:22 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Can we uneducated non-six owners see a pic of the part? Pat, I believe this is the part in question (minus the large sticker of course) Attached image(s) |
Rand |
Nov 6 2013, 07:27 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Irrelevant as long as the sealing surface is doing its job. Plastic can warp, metal can bend. (IMG:style_emoticons/default/confused24.gif)
The real question is, how does either do that? What have they been subjected to? Normal use isn't going to be a problem from either side. |
914itis |
Nov 6 2013, 10:27 PM
which one fits the 914? neck facing driver's side or passenger?
Jasfsmith |
Nov 7 2013, 12:22 PM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
nmorrm |
Dec 5 2013, 12:59 AM
sixnotfour |
Dec 5 2013, 09:18 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Just because 911's had tin has no reference to 914-6"s that all had plastic...
does an early 911 tin one fit IDK..Does a Later plastic 911 fit... IDK |
DamonsCarrera |
Dec 14 2013, 10:20 PM
Newbie Group: Members Posts: 36 Joined: 2-September 12 From: Chicago IL Member No.: 14,886 Region Association: Upper MidWest |
gms |
Dec 25 2013, 11:22 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
they were plastic
here is a bottom view |
sixnotfour |
Jan 4 2014, 09:12 PM
what no cold start nozzles ??
JmuRiz |
Dec 17 2015, 08:07 PM
914 Guru Group: Members Posts: 5,427 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Since I brought it up on the oil catchcan/breather thread, what hoses attach to the small side of the fixture on the back of the airbox?
gandalf_025 |
Dec 18 2015, 01:59 PM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
All the 6's I've seen came with plastic air cleaner housings.
I've seen more than a few that melted as a result of backfiring through the carbs. The air horns on the top of the webers were plastic also but many were replaced with metal ones by the dealers when they realized they could melt into the carbs for the same reason. |
gandalf_025 |
Dec 18 2015, 02:49 PM
Here is the result of a fairly mild melt from the carbs popping flame back.
The outer 2 air horns are plastic, the center one is metal.. |
porschetub |
Dec 23 2015, 12:11 AM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
thread hijack (IMG:style_emoticons/default/flag.gif) Is there an advantage to use the air box? does it help with the carbs noise? I mentioned this in another thread,the late great Bruce Anderson tested stock air cleaner vs k&ns,the k&n's dropped 1 hp over the factory one,he concluded in his tech notes it was a good design from Porsche There are other reasons I wouldn't use them,would rather spent the money elsewhere,they do look pretty however. Read an article on the bird about air cleaners some said steel some said plastic,appears there was a change around MY 70-71 for 911's,but no real set rule,besides many must have been changed over the years (IMG:style_emoticons/default/confused24.gif) . My plastic one on my motor is flamed on one side (found out why),so I cut blocks of wood and jammed them inside and heated with a heatgun then chilled with water,its slowing coming right. No question the steel one provides a better seal around the top of the carbs,this is very important.....anyone noticed how expensive these are getting now ,more 911 tax (IMG:style_emoticons/default/sad.gif) . |
Lo-Fi Version | Time is now: 17th May 2024 - 10:38 PM |
