used Torsion bar question |
GaroldShaffer |
Nov 9 2013, 10:52 PM
Very rusty parts car had a bunch of suspension upgrades to it (Bilstiens, turbo tie rods, 21 mm torsion bars). My question is one bar looks perfect, but the other some paint has (coating) has peeled off and has some surface rust. So is that a issue?
euro911 |
Nov 10 2013, 12:39 AM
Doesn't look that bad. Blast it and repaint it.
JoeSharp |
Nov 10 2013, 03:58 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) Yeah, what he said.
rfuerst911sc |
Nov 10 2013, 04:31 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I'm no metallurgist but you have a piece of solid 1 " steel ( aprox. ) so I don't think some surface rust is an issue. But did you mark them when you removed them for what side they came out of ? And marked front or back ? I think ( ??? ) a torsion bar will take a set once installed, I don't think you would want to install in a different car in a different orientation than the car they came out of. I say clean them up, prime/paint and install ( in correct orientation ).
GaroldShaffer |
Nov 10 2013, 06:41 AM
I'm no metallurgist but you have a piece of solid 1 " steel ( aprox. ) so I don't think some surface rust is an issue. But did you mark them when you removed them for what side they came out of ? And marked front or back ? I think ( ??? ) a torsion bar will take a set once installed, I don't think you would want to install in a different car in a different orientation than the car they came out of. I say clean them up, prime/paint and install ( in correct orientation ). Yes I did. (IMG:style_emoticons/default/beerchug.gif) |
northern chris |
Nov 10 2013, 08:51 AM
Newbie Group: Members Posts: 40 Joined: 13-August 05 From: Sherwood Park, Canada Member No.: 4,584 |
I'm no metallurgist but you have a piece of solid 1 " steel ( aprox. ) so I don't think some surface rust is an issue. But did you mark them when you removed them for what side they came out of ? And marked front or back ? I think ( ??? ) a torsion bar will take a set once installed, I don't think you would want to install in a different car in a different orientation than the car they came out of. I say clean them up, prime/paint and install ( in correct orientation ). Yes I did. (IMG:style_emoticons/default/beerchug.gif) I had a torsion bar break on the road once with a car that had not been used for a long time. The torsion bar broke right where a small rust patch was (I call it a stress raiser). I would only install a near perfect one, although having a torsion bar break on the road is not the worst thing that can happen. |
boxsterfan |
Nov 11 2013, 10:22 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
If this is a road car that you give spirited driving on the weekends, then blast it clean and paint it. Put it back in same orientation as others have said.
worn |
Nov 11 2013, 02:02 PM
can't remember Group: Members Posts: 3,155 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I'm no metallurgist but you have a piece of solid 1 " steel ( aprox. ) so I don't think some surface rust is an issue. But did you mark them when you removed them for what side they came out of ? And marked front or back ? I think ( ??? ) a torsion bar will take a set once installed, I don't think you would want to install in a different car in a different orientation than the car they came out of. I say clean them up, prime/paint and install ( in correct orientation ). Yes I did. (IMG:style_emoticons/default/beerchug.gif) I think the idea is that it is like scoring glass. The surface is where the stress is, and the torsion bars are heat treated. So they always break at a stress riser coming from corrosion. I have seen it happen in other pieces of steel. But they are expensive and if they didn't rust, but the paint just flaked of, why not? I think peening might be better than sand blasting, but that is just pulled out of .... well somewhat a guess. |
euro911 |
Nov 11 2013, 03:34 PM
Can you post a pic after blasting it (prior to painting if you haven't already done so)?
I wonder how this would relate to axle shafts. I know axles don't experience the same level of twisting, but I've seen axle shafts in worse condition that haven't snapped in half after 'reconditioning'. I realize they are a different animal and CV joints would typically fail before an axle would. It's just a question that came up in my mind (IMG:style_emoticons/default/confused24.gif) You could have it magna-fluxed to be on the safe side (IMG:style_emoticons/default/idea.gif) |
GaroldShaffer |
Nov 11 2013, 04:05 PM
Can you post a pic after blasting it (prior to painting if you haven't already done so)? I wonder how this would relate to axle shafts. I know axles don't experience the same level of twisting, but I've seen axle shafts in worse condition that haven't snapped in half after 'reconditioning'. I realize they are a different animal and CV joints would typically fail before an axle would. It's just a question that came up in my mind (IMG:style_emoticons/default/confused24.gif) You could have it magna-fluxed to be on the safe side (IMG:style_emoticons/default/idea.gif) Mark I'm not going to put them in my 914 as I already have a set in mine. My plan was to post these for sale in the classifieds. I feel that it would be fine to use once cleanup and painted, but I am not expert and that is why I asked. |
Nov 11 2013, 04:10 PM
Resident German Group: Admin Posts: 41,637 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have to agree with others here, the ones i have seen break (two so far) all broke right where they had surface rust.
My guess would be (and i'm no metal expert) that once the surface treatment is compromised they shouldn't be used anymore. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 06:16 PM |
