QUOTE(Garold Shaffer @ Nov 10 2013, 04:41 AM)
QUOTE(rfuerst911sc @ Nov 10 2013, 04:31 AM)
I'm no metallurgist but you have a piece of solid 1 " steel ( aprox. ) so I don't think some surface rust is an issue. But did you mark them when you removed them for what side they came out of ? And marked front or back ? I think ( ??? ) a torsion bar will take a set once installed, I don't think you would want to install in a different car in a different orientation than the car they came out of. I say clean them up, prime/paint and install ( in correct orientation ).
Yes I did.
I think the idea is that it is like scoring glass. The surface is where the stress is, and the torsion bars are heat treated. So they always break at a stress riser coming from corrosion. I have seen it happen in other pieces of steel. But they are expensive and if they didn't rust, but the paint just flaked of, why not? I think peening might be better than sand blasting, but that is just pulled out of .... well somewhat a guess.
