911 Oil Pressure/Temp Gauge |
Bulldog9 |
Nov 13 2013, 09:03 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Evening Gents, I'm looking to upgrade the gauge cluster in my 912E (type 4 engine) and would like to add one of the dual gauges that has oil temp, oil pressure, and oil warning/volt idiot lights.
I know the 912E has an oil temp gauge, and idiot light, but how would I, can I add a pressure gauge too? is there a combo sender that I can hook up? or is it a second sensor? Thanks! |
Nov 13 2013, 09:15 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
is there a combo sender that I can hook up? I would assume you can use the same dual sender that is available (aftermarket) for the 914. (IMG:style_emoticons/default/idea.gif) |
Nov 13 2013, 10:53 PM
Yes, that should work fine.
You can use one of these types of sender: http://www.pelicanparts.com/catalog/shopca..._pg2.htm#item11 I am not sure if the resistance range on the 911 pressure gauge matches one of the senders or not. The sender does not fit well with the distributor. A common way to relocate it is to use a grease gun hose threaded into the case, and some brass plumbing adapters to hook it up to the sender. And make sure to ground the outside of the sender. --DD |
type47 |
Nov 14 2013, 07:04 AM
is there a combo sender that I can hook up? I would assume you can use the same dual sender that is available (aftermarket) for the 914. (IMG:style_emoticons/default/idea.gif) VDO 360-009 dual sender for oil pressure VDO 323-055 oil temp drain plug sender for oil temp use these with VDO pressure and temp gauges (use oil temp instead of cylinder head temp) |
larryM |
Nov 15 2013, 11:06 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
do you mean you want to use a 911 combo gage in the dash - instead of the aftermarket setup shown above?
yes - you can do that - i just sold such a 911 gage for $200 yes you need the correct sender - depends on if the gage is 10 bar or 5 bar . |
Bulldog9 |
Nov 16 2013, 09:09 AM
Yes, thats exactly what I want to do. My plan is a bit crazy, plan to keep the 3 center gauges, and put vents in outer where fuel gague and clock are (this is a 912E).
From left to right vent - Oil Temp/Pressure - Tach - Speedo - vent Will relocate 2" VDO clock, Volt, and Fuel Gauge to lower dash in place of the ashtray. I want to do this, as I wanted to add an oil pressure gauge either way, and in looking around saw that the 911 had a dual oil temp & pressure gauge, figured this would look better. I could do a 4 gauge stack below, but like the idea of temp and pressure in same location not one in a small vdo in teh lower dash and one in stock positiuon. The Vent system is basically dash vents from a Ford F-15o, plumbed up to a small fan and filter that will pull air in from the cowl when needed. SHould help in the warmer weather to move air through the cabin. I also have a crazy plan for the heat as well, have built two small 150W electric heat boxes that will be spliced into the heat duct tubing just before the dash mixing flapper box things. They are basically the size of a 4" electrical box, and draw 2-3 amps each. They put out a nice amount of medium hot/warm air. The benifit of this is that the stock rear blower, switch/relay flapper box system remains intact, and other than an extra dash swiich, the system will look stock. Have to cut about 3" of the air tube out to splice the heater box in each side and then plumb it in. Once carpet goes back in and cowl/footwell is covered will be completely transparent. Took me almost 2 years to find the right elements combining size with low draw and good heat output. I bench tested them with a 12V power supply for 2 hours and they put out good heat, never gor redhot, and airflow produced plenty of warm air. Because they are so close to the front mixing/flapper units, the retained heat should be fine, and the stock air controls are left as original. Here is a link if interested. http://www.ebay.ca/itm/321100648864?ssPage...984.m1439.l2649 I've got a diagram of the system and will do pics of install when finished. But back to the gauges and senders, I will start looking for the right gauge/price and also the senders. Good to know it will work.! do you mean you want to use a 911 combo gage in the dash - instead of the aftermarket setup shown above? yes - you can do that - i just sold such a 911 gage for $200 yes you need the correct sender - depends on if the gage is 10 bar or 5 bar . |
Dtjaden |
Nov 16 2013, 09:32 AM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
Yes, thats exactly what I want to do. My plan is a bit crazy, plan to keep the 3 center gauges, and put vents in outer where fuel gague and clock are (this is a 912E). From left to right vent - Oil Temp/Pressure - Tach - Speedo - vent Will relocate 2" VDO clock, Volt, and Fuel Gauge to lower dash in place of the ashtray. I want to do this, as I wanted to add an oil pressure gauge either way, and in looking around saw that the 911 had a dual oil temp & pressure gauge, figured this would look better. I could do a 4 gauge stack below, but like the idea of temp and pressure in same location not one in a small vdo in teh lower dash and one in stock positiuon. The Vent system is basically dash vents from a Ford F-15o, plumbed up to a small fan and filter that will pull air in from the cowl when needed. SHould help in the warmer weather to move air through the cabin. I also have a crazy plan for the heat as well, have built two small 150W electric heat boxes that will be spliced into the heat duct tubing just before the dash mixing flapper box things. They are basically the size of a 4" electrical box, and draw 2-3 amps each. They put out a nice amount of medium hot/warm air. The benifit of this is that the stock rear blower, switch/relay flapper box system remains intact, and other than an extra dash swiich, the system will look stock. Have to cut about 3" of the air tube out to splice the heater box in each side and then plumb it in. Once carpet goes back in and cowl/footwell is covered will be completely transparent. Took me almost 2 years to find the right elements combining size with low draw and good heat output. I bench tested them with a 12V power supply for 2 hours and they put out good heat, never gor redhot, and airflow produced plenty of warm air. Because they are so close to the front mixing/flapper units, the retained heat should be fine, and the stock air controls are left as original. Here is a link if interested. http://www.ebay.ca/itm/321100648864?ssPage...984.m1439.l2649 I've got a diagram of the system and will do pics of install when finished. But back to the gauges and senders, I will start looking for the right gauge/price and also the senders. Good to know it will work.! do you mean you want to use a 911 combo gage in the dash - instead of the aftermarket setup shown above? yes - you can do that - i just sold such a 911 gage for $200 yes you need the correct sender - depends on if the gage is 10 bar or 5 bar . 150 watts at 12 volts = 12.5 amps. Either these don't put out 150 watts of heat or they will draw much more than the 2-3 amps you mentioned. 12v at 3a = 36 watts = 122 btu's of heat. |
Dtjaden |
Nov 16 2013, 09:40 AM
Yes, thats exactly what I want to do. My plan is a bit crazy, plan to keep the 3 center gauges, and put vents in outer where fuel gague and clock are (this is a 912E). From left to right vent - Oil Temp/Pressure - Tach - Speedo - vent Will relocate 2" VDO clock, Volt, and Fuel Gauge to lower dash in place of the ashtray. I want to do this, as I wanted to add an oil pressure gauge either way, and in looking around saw that the 911 had a dual oil temp & pressure gauge, figured this would look better. I could do a 4 gauge stack below, but like the idea of temp and pressure in same location not one in a small vdo in teh lower dash and one in stock positiuon. The Vent system is basically dash vents from a Ford F-15o, plumbed up to a small fan and filter that will pull air in from the cowl when needed. SHould help in the warmer weather to move air through the cabin. I also have a crazy plan for the heat as well, have built two small 150W electric heat boxes that will be spliced into the heat duct tubing just before the dash mixing flapper box things. They are basically the size of a 4" electrical box, and draw 2-3 amps each. They put out a nice amount of medium hot/warm air. The benifit of this is that the stock rear blower, switch/relay flapper box system remains intact, and other than an extra dash swiich, the system will look stock. Have to cut about 3" of the air tube out to splice the heater box in each side and then plumb it in. Once carpet goes back in and cowl/footwell is covered will be completely transparent. Took me almost 2 years to find the right elements combining size with low draw and good heat output. I bench tested them with a 12V power supply for 2 hours and they put out good heat, never gor redhot, and airflow produced plenty of warm air. Because they are so close to the front mixing/flapper units, the retained heat should be fine, and the stock air controls are left as original. Here is a link if interested. http://www.ebay.ca/itm/321100648864?ssPage...984.m1439.l2649 I've got a diagram of the system and will do pics of install when finished. But back to the gauges and senders, I will start looking for the right gauge/price and also the senders. Good to know it will work.! do you mean you want to use a 911 combo gage in the dash - instead of the aftermarket setup shown above? yes - you can do that - i just sold such a 911 gage for $200 yes you need the correct sender - depends on if the gage is 10 bar or 5 bar . 150 watts at 12 volts = 12.5 amps. Either these don't put out 150 watts of heat or they will draw much more than the 2-3 amps you mentioned. 12v at 3a = 36 watts = 122 btu's of heat. Out of curiosity I did a quick calculation on the amount of heat need to increase the cabin temperature 30 degrees and it works out to about 270 watts. So this may not be a bad idea if your electrical system can support the 25 amps needed for a pair of these heaters. Keep us informed about how this works out! |
Bulldog9 |
Nov 16 2013, 10:02 AM
150 watts at 12 volts = 12.5 amps. Either these don't put out 150 watts of heat or they will draw much more than the 2-3 amps you mentioned. 12v at 3a = 36 watts = 122 btu's of heat. I did the same calculations, and was planning to do a larger alternator (rumors of a 100 amp type 4 alt for campers, but havent found more than 70) and second battery in the smuggler box.... However when I hooked these up to my bench powersupply (something I built in High School circa 1980) the amp meter only showed 2.5 amps for one and when both were hooked up the amp meter showed around 4-4.5. I will play around a bit more, and put a multimeter on them. Will definately keep everyone posted. |
Bulldog9 |
Nov 17 2013, 05:20 PM
I ended up getting a dual gauge from an 86 911, once I have the part in hand will figure out if I need the 150 or 80 lb sender. Being that I have the tins off, will likely modify the tin to accomodate the new sender. Now when it comes to the temp sender, I imagine that will go down at teh taco plate, and use the same sender from the 912? or will I need a different one?
Thanks! Pics will follow. is there a combo sender that I can hook up? I would assume you can use the same dual sender that is available (aftermarket) for the 914. (IMG:style_emoticons/default/idea.gif) VDO 360-009 dual sender for oil pressure VDO 323-055 oil temp drain plug sender for oil temp use these with VDO pressure and temp gauges (use oil temp instead of cylinder head temp) |
Nov 17 2013, 10:43 PM
The sump is for the temp sender.
The pressure sender is the dual-pole one. It screws in next to the distributor. There isn't usually enough room for it, though, so a common thing to do is screw in a grease gun hose to the hole in the case, and then use some adaptors to connect it to the sender. Make sure to ground the body of the sender if you go that route. --DD |
oldschool |
Nov 17 2013, 11:11 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
Evening Gents, I'm looking to upgrade the gauge cluster in my 912E (type 4 engine) and would like to add one of the dual gauges that has oil temp, oil pressure, and oil warning/volt idiot lights. I know the 912E has an oil temp gauge, and idiot light, but how would I, can I add a pressure gauge too? is there a combo sender that I can hook up? or is it a second sensor? Thanks! Steve, how about some pictures of you 912E...I'm a fan. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:18 PM |
