Yes, thats exactly what I want to do. My plan is a bit crazy, plan to keep the 3 center gauges, and put vents in outer where fuel gague and clock are (this is a 912E).
From left to right vent - Oil Temp/Pressure - Tach - Speedo - vent
Will relocate 2" VDO clock, Volt, and Fuel Gauge to lower dash in place of the ashtray.
I want to do this, as I wanted to add an oil pressure gauge either way, and in looking around saw that the 911 had a dual oil temp & pressure gauge, figured this would look better. I could do a 4 gauge stack below, but like the idea of temp and pressure in same location not one in a small vdo in teh lower dash and one in stock positiuon.
The Vent system is basically dash vents from a Ford F-15o, plumbed up to a small fan and filter that will pull air in from the cowl when needed. SHould help in the warmer weather to move air through the cabin.
I also have a crazy plan for the heat as well, have built two small 150W electric heat boxes that will be spliced into the heat duct tubing just before the dash mixing flapper box things. They are basically the size of a 4" electrical box, and draw 2-3 amps each. They put out a nice amount of medium hot/warm air. The benifit of this is that the stock rear blower, switch/relay flapper box system remains intact, and other than an extra dash swiich, the system will look stock. Have to cut about 3" of the air tube out to splice the heater box in each side and then plumb it in. Once carpet goes back in and cowl/footwell is covered will be completely transparent.
Took me almost 2 years to find the right elements combining size with low draw and good heat output. I bench tested them with a 12V power supply for 2 hours and they put out good heat, never gor redhot, and airflow produced plenty of warm air. Because they are so close to the front mixing/flapper units, the retained heat should be fine, and the stock air controls are left as original. Here is a link if interested.
http://www.ebay.ca/itm/321100648864?ssPage...984.m1439.l2649 I've got a diagram of the system and will do pics of install when finished.
But back to the gauges and senders, I will start looking for the right gauge/price and also the senders. Good to know it will work.!
QUOTE(larryM @ Nov 16 2013, 12:06 AM)
do you mean you want to use a 911 combo gage in the dash - instead of the aftermarket setup shown above?
yes - you can do that
- i just sold such a 911 gage for $200
yes you need the correct sender - depends on if the gage is 10 bar or 5 bar
