Will this wheel fit ?, Replica ceterlines 13lbs |
Sawfish |
Nov 14 2013, 11:34 AM
Newbie Group: Members Posts: 43 Joined: 28-January 09 From: San Diego Member No.: 9,990 Region Association: Southwest Region |
Looking for some guidance as to whether or not these wheels will fit my 72 914.
http://www.ebay.com/itm/VW-CENTERLINE-CLAS...#ht_2867wt_1363 I currently have empi 8 spokes and I am looking to reduce unsprung weight without breaking the bank. Any feedback? (IMG:style_emoticons/default/wacko.gif) |
Nov 14 2013, 01:22 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Any feedback? They will bolt up to your 914 but it seems they have the offset to fit a bug/ghia in which case you'll be limited to a narrow tire, if you can fit them at all. (IMG:style_emoticons/default/popcorn[1].gif) |
Sawfish |
Nov 14 2013, 01:25 PM
Any feedback? They will bolt up to your 914 but it seems they have the offset to fit a bug/ghia in which case you'll be limited to a narrow tire, if you can fit them at all. (IMG:style_emoticons/default/popcorn[1].gif) I currently run a 205/50/15 on a 5-1/2 width anything larger will cost me points. |
rick 918-S |
Nov 14 2013, 01:39 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I had a set of centerline "style" wheels on one of the 914's I purchased. The P.O. took a grinder and ground the shit out of the calipers. The part that faces the wheels because when you tightened the "VW" wheels down the inside of the wheel locked against the caliper. The calipers were junk after that. I scrapped the wheels and the calipers.
Nov 14 2013, 02:31 PM
I currently run a 205/50/15 on a 5-1/2 width anything larger will cost me points. With the bug offset, i highly doubt you'll be able to run 205s ... (IMG:style_emoticons/default/shades.gif) |
jimkelly |
Nov 14 2013, 02:39 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
your empi's are probably vw offset too.
you want a set of, fuchs, pedrinis, mahles, or sport steel. for best offset (4.5" I think) and 5.5 width. jim |
JRust |
Nov 14 2013, 02:46 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
your empi's are probably vw offset too. If he is running 205's no way the Empi's are VW stock. Unless his car is flared (IMG:style_emoticons/default/confused24.gif) . I have seen centerline's with the correct offset. Steve in Portland has a set on his Raby powered 914. Actually maybe they just look like centerlines? They do exist I believe. Just email the people selling & ask for the measurement on the backside |
ventedrib |
Nov 14 2013, 03:12 PM
Member Group: Members Posts: 104 Joined: 10-August 08 From: Monroe La. Member No.: 9,406 Region Association: South East States |
Centerline will make wheels any offset U need.
jimkelly |
Nov 14 2013, 03:23 PM
here is sawfish catching some Gsssssssssssssssssss
http://www.youtube.com/watch?v=ZV1w-v24jZg sounds good (IMG:style_emoticons/default/biggrin.gif) |
damesandhotrods |
Nov 14 2013, 07:18 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
They sound like a salesman, and they don’t know their product. The Beetle has a different offset than the Type 3 and Ghia. 914s, Type 3s, and Ghias are pretty much the same offset. Sure they’re 4 lug and they’ll bolt up but that’s a long way from fitting. If you need wheels I’d check The Samba.com before eBay…
rhodyguy |
Nov 15 2013, 03:34 PM
fwiw, cip1 sells what appears to be the same wheel for $99.95. as noted, the backspacing is pretty shallow.
watsonrx13 |
Nov 16 2013, 11:32 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
So is the off set of the wheels pictured?
What is the preferred off set for our cars? What would be the minimum off set be for a flared car? --- Rob |
jimkelly |
Nov 16 2013, 11:49 AM
here is as a sport steel wheel, and they are 18.5 lbs each.
http://www.914world.com/bbs2/index.php?sho...hl=wheel+weight Fuchs == 13 lbs = 4 lug fuch weight Mahles == 14 lbs = mahle weight Pedrinis == 17 lbs = pedrini weight the piece of wood I am using is on one lip but tilted up and one an outter edge of the wheel, so not perfectly level, but close. appears to be 4.25" offset, subtracting for the tilt in my wood (IMG:style_emoticons/default/biggrin.gif) depending on the cut of the tire model, some 205x50x15 will rub inner wheel well. I think I like 195x60x15, but again, it depends on mfr of tire. since fuchs are the least weight. my guess is one could lose another 1lb or so by milling the openings a bit more? Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:59 PM |
