here is as a sport steel wheel, and they are 18.5 lbs each.
http://www.914world.com/bbs2/index.php?sho...hl=wheel+weightFuchs == 13 lbs = 4 lug fuch weight
Mahles == 14 lbs = mahle weight
Pedrinis == 17 lbs = pedrini weight
the piece of wood I am using is on one lip but tilted up and one an outter edge of the wheel, so not perfectly level, but close.
appears to be 4.25" offset, subtracting for the tilt in my wood
depending on the cut of the tire model, some 205x50x15 will rub inner wheel well. I think I like 195x60x15, but again, it depends on mfr of tire.
since fuchs are the least weight. my guess is one could lose another 1lb or so by milling the openings a bit more?
