Question about Auxiliary Air Regulator Valve (Porsche or Bosch replacement), Porsche part number: 022 906 045 |
tumamilhem |
Nov 14 2013, 01:55 PM
LUFTBRIGADE Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States |
I think I found the problem to my high idle and it seems my AAR valve is stuck/gone bad. They are no longer available but rebuilt ones are as are Bosch replacements.
Has anybody bought the rebuilt AAR valve from Auto Atlanta and if so, are you happy with it? For my car 1974 2.0 w/D-jet, here is the link: http://www.autoatlanta.com/Porsche-Rebuilt...B022906045.html If you have a Bosch replacement, which part number is it? I have been told a couple different numbers: 280 40 007 and 0 280 140 101 (mind you, this is for a 1974 2.0). Would it be better to get a new Bosch replacement or a rebuilt original from AA? Also found some rebuilt ones on Samba. Thanks in advance for your input! (IMG:style_emoticons/default/driving.gif) |
luskesq |
Nov 14 2013, 04:00 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
I don't have a 2.0 so I can't help you there. Check out Anders site (http://members.rennlist.com/pbanders/DJetParts.htm#troubleshoot)and scroll down the the AAR discussion and follow his suggestions, they worked for me.
I'd certainly put in a WTB add in the classifieds before going to AA. Keith |
JawjaPorsche |
Nov 14 2013, 04:03 PM
Blast a can of pb blaster into the inlet, shake it, let it dump out...keep doing it untill all the rust falls out, and dirt.
You can run two wires to it for testing. Power lead is obvious, body needs to be grounded. No air should blow through when it's closed, if it does, let it cool down and clean it again....needs to be one to clean, so cold.. Remove it and PB it or WD40 it. Placing it in the freezer for an hour then apply 12V. Repeat until it fully opens & closes. It will operate w/o power but takes longer to seal off when engine heat is it's only source |
bulitt |
Nov 14 2013, 04:11 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
If you contact a Bosch distributor with the number I would be amazed they are NLA. Darn near every car with their F.I. from 70-80's used this part.
SLITS |
Nov 14 2013, 04:24 PM
The one for the 1.8 LJet will work as well. You just have to hook up a power wire and ground as it has a two spade terminal connection.
Jeffs9146 |
Nov 14 2013, 04:32 PM
I have heard if you put it in a plastic bag with enough PB to cover it and let is soak for a few days before testing that people have had good luck!
Cap'n Krusty |
Nov 14 2013, 05:00 PM
If you contact a Bosch distributor with the number I would be amazed they are NLA. Darn near every car with their F.I. from 70-80's used this part. Be amazed. They've been obsolete for years, if not decades. The only application was for D-jetronic on 914s and T4s. The L-jet version is readily available and can be made to fit. The Cap'n |
TheCabinetmaker |
Nov 14 2013, 06:21 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Cap'n, does the airflow amount differ between the two?
turk22 |
Nov 14 2013, 08:07 PM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
guy on the samba has about a dozen for sale:
http://www.thesamba.com/vw/classifieds/detail.php?id=1123061 |
Java2570 |
Nov 14 2013, 08:27 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I bought one from Henry (Hencar on Samba) about a year ago, still working so far.....
Drex |
Jun 15 2023, 06:57 AM
Member Group: Members Posts: 170 Joined: 1-December 22 From: Guthrie Center, Iowa Member No.: 27,003 Region Association: None |
Auto Atlanta list a new AAR at $345/09
and the core at $200 does this mean your cost is $145.09 if you send in your old AAR? thanks D Rex |
76-914 |
Jun 15 2023, 07:25 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Couldn't help but notice that 3 deceased members posted one after another and each pasted in consecutive years. Miss ya Ron. (IMG:style_emoticons/default/sad.gif) Looks like it but call and verify 1st. Do try soaking in a solvent for at least 24 hr's then throw it in the freezer overnight then hit it w/ 12v. Watch the cylinder to see if it moves. If it moves even a tiny bit rinse and repeat until full movement. (IMG:style_emoticons/default/beerchug.gif)
brant |
Jun 15 2023, 07:34 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I noticed that too
Some of my favorite people on this old thread And started by the one world member I have blocked |
JeffBowlsby |
Jun 15 2023, 07:54 AM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Auto Atlanta list a new AAR at $345/09 and the core at $200 does this mean your cost is $145.09 if you send in your old AAR? thanks D Rex This is how it works. Using the numbers you posted, it would be $345.09 +$200. core, or $545.09 out of pocket. Submitting a rebuildable core gets you a $200. refund, or $345.09 total cost. If you don't return a core then its $545.09 total cost. |
StarBear |
Jun 15 2023, 08:23 AM
Senior Member Group: Members Posts: 1,913 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Blast a can of pb blaster into the inlet, shake it, let it dump out...keep doing it untill all the rust falls out, and dirt. You can run two wires to it for testing. Power lead is obvious, body needs to be grounded. No air should blow through when it's closed, if it does, let it cool down and clean it again....needs to be one to clean, so cold.. Remove it and PB it or WD40 it. Placing it in the freezer for an hour then apply 12V. Repeat until it fully opens & closes. It will operate w/o power but takes longer to seal off when engine heat is it's only source (IMG:style_emoticons/default/agree.gif) Will solve the issue virtually every time. I’m 2 for 2. |
ThinAir |
Jun 26 2023, 03:02 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
emerygt350 |
Jun 26 2023, 03:18 PM
Advanced Member Group: Members Posts: 2,147 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Be absolutely sure it actually is the problem.
Lo-Fi Version | Time is now: 10th June 2024 - 07:26 PM |
