How to remove powdercoating, Want to change colors |
skline |
Dec 26 2004, 01:48 PM
Does anyone know if powdercoating can be removed? I got a set of wheels from MikeZ and want to change color. Red just doesnt go with any color I want to paint my car. Can they be stripped and brought back to original? The silver or grey would go nicely with just about any color I go with.
Aaron Cox |
Dec 26 2004, 01:49 PM
bead blast?
edit: you working today? may be able to len a hand..... |
skline |
Dec 26 2004, 01:51 PM
I have to go help with 2 satellite setups but then I will be back to work on the car. It's almost 12 now so I will probably be back around 2 ro 3.
Aaron Cox |
Dec 26 2004, 01:53 PM
lemme know (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Joe Bob |
Dec 26 2004, 02:16 PM
If you are gonna go black....just rattle can them. Scrtach them, rattle can them again....silver same thing.
DonTraver |
Dec 26 2004, 03:03 PM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
Just use paint remover from Home Depot, etc. Works good, no scratches.
Carrera916 |
Dec 26 2004, 10:22 PM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
the last time I dealt with powdercoated engine tins, it had to be bead blast with red oxide which last a bit longer than glass bead. it does not come off easily unless the powdercoat job was done poorly.
i don't think paint remover could do the job.....i might be wrong but I know i've tried pretty much everything else but the blast to get the coat off ....very hard until i used the red oxide media, aahh a bit better.... j |
skline |
Dec 26 2004, 10:35 PM
I am at work right now till around midnight, I will try it tomorrow on the back side of one of the wheels and see if the paint stripper will take it off. If not, I may just do as Mike suggests and just rattle can them with some silver. Maybe I will use that ceramic type paint, it seems to hold up pretty well and it looks nice.
Aaron Cox |
Dec 26 2004, 10:36 PM
can you powdercoat over powder coat? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
skline |
Dec 26 2004, 10:48 PM
I asked that too and Mike said he didnt think it would stick to it without stripping off the old first. Which makes sense when you consider it has to bond to the metal magnetically.
Aaron Cox |
Dec 26 2004, 11:09 PM
wrong.... Electrostatically (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) i dun lurned thangs at skool (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
skline |
Dec 26 2004, 11:14 PM
Ok Mr. brains, now explain Electrostatic and the effects. Positive attracted to negative??? Hmmm |
Trekkor |
Dec 26 2004, 11:27 PM
Why not try wiping one wheel down with acetone and painting it to your liking?
Maybe hit it with 0000 steel wool. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) KT |
skline |
Dec 26 2004, 11:28 PM
Yeah, That is what I will try tomorrow if I ever got home from work.
Trekkor |
Dec 26 2004, 11:33 PM
How about a pic of those wheels?
BTW , you can get a "no sand" paint prep for painting over paint. That might be worth a try. KT |
skline |
Dec 26 2004, 11:43 PM
I will get pics tomorrow sometime and post them. Kind of a before and after thing. I still have to get spacers to install them.
John |
You can powdercoat over powdercoat, but it doesnt turn out as nice.
One could heat the part prior to spraying the powder (which melts it as it is applied). One way to "strip" the parts would be heat. They could be burned off (potentially hazardous to wheels). Other than that, bead or sand blasting would probably be the way to go. If you are going to re-powder coat the wheels, the pits created while blasting will be filled in and smoothed out as the powder flows out during the curing process (oven). I don't think any paint will stick well to powder coated parts. just my $0.02 |
Mueller |
Dec 27 2004, 01:19 AM
please, no pictures until they are freshly painted...I don't think I can stand seeing those "hooker-lipstick-red" wheels anymore (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I'd try scuffing the coating and paint or the chemical strip..it's not going to be easy or quick (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
spare time toys |
Dec 27 2004, 06:52 AM
Yes you can. I had a CBR600 Honda I took apart and had the frame powder coated in blue then a clear powder coat over that it came out sweet. |
East coaster |
Dec 27 2004, 07:05 AM
Senior Member Group: Members Posts: 1,673 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
Paint remover works (the good stuff). I remove that crap from anything I ever get that has powder coating on it. Powder coating sucks! At least where I live, powder coating is a death warrant for the part that's been coated. It's guaranteed to corrode the part. Around here paint will protect the part 10 times better.
Lo-Fi Version | Time is now: 18th May 2024 - 11:53 PM |
