skline
Dec 26 2004, 01:48 PM
Does anyone know if powdercoating can be removed? I got a set of wheels from MikeZ and want to change color. Red just doesnt go with any color I want to paint my car. Can they be stripped and brought back to original? The silver or grey would go nicely with just about any color I go with.
Aaron Cox
Dec 26 2004, 01:49 PM
bead blast?
edit: you working today? may be able to len a hand.....
skline
Dec 26 2004, 01:51 PM
I have to go help with 2 satellite setups but then I will be back to work on the car. It's almost 12 now so I will probably be back around 2 ro 3.
Aaron Cox
Dec 26 2004, 01:53 PM
lemme know
Joe Bob
Dec 26 2004, 02:16 PM
If you are gonna go black....just rattle can them. Scrtach them, rattle can them again....silver same thing.
DonTraver
Dec 26 2004, 03:03 PM
Just use paint remover from Home Depot, etc. Works good, no scratches.
Carrera916
Dec 26 2004, 10:22 PM
the last time I dealt with powdercoated engine tins, it had to be bead blast with red oxide which last a bit longer than glass bead. it does not come off easily unless the powdercoat job was done poorly.
i don't think paint remover could do the job.....i might be wrong but I know i've tried pretty much everything else but the blast to get the coat off ....very hard until i used the red oxide media, aahh a bit better....
j
skline
Dec 26 2004, 10:35 PM
I am at work right now till around midnight, I will try it tomorrow on the back side of one of the wheels and see if the paint stripper will take it off. If not, I may just do as Mike suggests and just rattle can them with some silver. Maybe I will use that ceramic type paint, it seems to hold up pretty well and it looks nice.
Aaron Cox
Dec 26 2004, 10:36 PM
can you powdercoat over powder coat?
skline
Dec 26 2004, 10:48 PM
I asked that too and Mike said he didnt think it would stick to it without stripping off the old first. Which makes sense when you consider it has to bond to the metal magnetically.
Aaron Cox
Dec 26 2004, 11:09 PM
QUOTE (skline @ Dec 26 2004, 09:48 PM) |
....... bond to the metal magnetically. |
wrong....
Electrostatically
i dun lurned thangs at skool
skline
Dec 26 2004, 11:14 PM
QUOTE (Aaron Cox @ Dec 26 2004, 09:09 PM) |
QUOTE (skline @ Dec 26 2004, 09:48 PM) | ....... bond to the metal magnetically. |
wrong....
Electrostatically
i dun lurned thangs at skool |
Ok Mr. brains, now explain Electrostatic and the effects.
Positive attracted to negative??? Hmmm
Trekkor
Dec 26 2004, 11:27 PM
Why not try wiping one wheel down with acetone and painting it to your liking?
Maybe hit it with 0000 steel wool.
KT
skline
Dec 26 2004, 11:28 PM
Yeah, That is what I will try tomorrow if I ever got home from work.
Trekkor
Dec 26 2004, 11:33 PM
How about a pic of those wheels?
BTW , you can get a "no sand" paint prep for painting over paint. That might be worth a try.
KT
skline
Dec 26 2004, 11:43 PM
I will get pics tomorrow sometime and post them. Kind of a before and after thing. I still have to get spacers to install them.
John
You can powdercoat over powdercoat, but it doesnt turn out as nice.
One could heat the part prior to spraying the powder (which melts it as it is applied).
One way to "strip" the parts would be heat. They could be burned off (potentially hazardous to wheels). Other than that, bead or sand blasting would probably be the way to go.
If you are going to re-powder coat the wheels, the pits created while blasting will be filled in and smoothed out as the powder flows out during the curing process (oven).
I don't think any paint will stick well to powder coated parts.
just my $0.02
Mueller
Dec 27 2004, 01:19 AM
QUOTE (trekkor @ Dec 26 2004, 10:33 PM) |
KT |
please, no pictures until they are freshly painted...I don't think I can stand seeing those "hooker-lipstick-red" wheels anymore
I'd try scuffing the coating and paint or the chemical strip..it's not going to be easy or quick
spare time toys
Dec 27 2004, 06:52 AM
QUOTE (Aaron Cox @ Dec 26 2004, 11:36 PM) |
can you powdercoat over powder coat? |
Yes you can. I had a CBR600 Honda I took apart and had the frame powder coated in blue then a clear powder coat over that it came out sweet.
East coaster
Dec 27 2004, 07:05 AM
Paint remover works (the good stuff). I remove that crap from anything I ever get that has powder coating on it. Powder coating sucks! At least where I live, powder coating is a death warrant for the part that's been coated. It's guaranteed to corrode the part. Around here paint will protect the part 10 times better.
Joe Bob
Dec 27 2004, 07:32 AM
Electrostatic can be done with both powder and wet systems. You ground the part, charge the paint, and it's attracted to the part because of the opposite charge. It can actaully "wrap" around some objects and coat the other side....it does not like tight corners...Faraday Cage Effect.
The advantage is that more paint is attracted to the product and you get a higher transfer effeciency..more objects per gallon of paint...powder not sticking can also be recovered and reused...to a point.
Powder coating REQUIRES an oven to melt the paint....thermoset/thermoplat....one will remelt....the other will not and is permanent and can only be abrasive blasted off.
You CAN powder coat over powder....you have to turn up the "juice" though nad it's not as effective in coverage....
skline
Dec 28 2004, 01:31 AM
Ok, Powdercoating can be removed with chemical strippers. I just sprayed about a 2 inch spot on the back side of one of the rear rims and let it set for about 15 minutes. It took it off just like paint. The finish underneath however is very rough. I am wondering if it will be that rough all over. If so, the only option is to have them re-powdercoated to make them smooth. I dont think they could polish them and make them come out nice. So now my question is, should I just have the powdercoater bead blast them and recoat them in the color I want? Or should I strip them myself and then have them coated?
spare time toys
Dec 28 2004, 08:18 AM
do it your self and save a couple of bucks.
Trekkor
Dec 28 2004, 10:20 AM
Sometimes, I just let the pros do it.
What they do in a short time can take us days. ( Weeks. )
Put your energy somewhere else.
Unless you have lots of spare time and money.
KT
Joe Bob
Dec 28 2004, 10:36 AM
Scott....those wheels were "cosmetically challenged" when I got them.....I had them bead blasted and then double powder coated. They are smooth due to the powder. Blasting them again will just piss them off....do the rattle can...trust me...
skline
Dec 28 2004, 10:41 AM
The drawback to the rattle can job is that it will scratch when they put the tires back on. Touching it up with the tires on would be tough to not get paint on the tires and that would look like crap.
Joe Bob
Dec 28 2004, 10:45 AM
Your going black right? Little masking tape and yer in....
skline
Dec 28 2004, 10:47 AM
Actually, I wanted to go Silver like the factory color or maybe that ceramic looking silver color. I think it would look nice.
Aaron Cox
bead blast it all off....then powdercoat them silver
Trekkor
Dec 28 2004, 10:58 AM
Scott, try to paint
one first. Then decide.
try that Hammertone finish Rustoleum in silver.
If you have to do a little touch up now and then...no big.
KT
Joe Bob
Dec 28 2004, 11:02 AM
Pebble finish....bead blast and leave it....make like yer from Bedrock....
spunone
Dec 28 2004, 11:22 AM
You can use aircraft paint stripper then bead blast.Or give Burlington eng.in Orange Ca. a call they have done stripping of Powdercoating on wheels .Just my .02
skline
Dec 28 2004, 12:28 PM
Just got off the phone with Specialized in HB, they quoted me 60 per wheel including stripping. They said if I strip them myself, it would be about 15 bucks less per wheel. Does that sound like a good price? I know it cost me about 65 per wheel to get my Fuchs polished.
Gint
Dec 28 2004, 12:43 PM
At $15 per, I'd just let them do all the work. Blast and coat.
Trekkor
Dec 28 2004, 01:14 PM
Send them out.
KT
Joe Bob
Dec 28 2004, 03:41 PM
Cheap....do it.
If you don't like the tires, since you are gonna dismount them anyways......lemme know.
