Need help STAT with valve adjustment, Having some issues... |
'70PVW914 |
Nov 22 2013, 05:26 PM
Newbie Group: Members Posts: 29 Joined: 1-November 13 From: Boulder, Co Member No.: 16,594 Region Association: Rocky Mountains |
Hey,
Seem like every time I set out to do something, something fails, or doesn't work the way it should. I am using the Pelican Guide for Valve Adjustments.... I have removed my heater boxes and heat pipes on both sides, (coca cola treatment and wire brushed) have new valve cover gaskets ready to go... Just adjusted my 1st cylinder valves no problem .006 intake .008 exhaust (they are that left to right correct)...and now when my #2 cylander is at tdc (large score in flywheel in the center of transmission gap) the feeler guages will not fit behind the valves! when i move the wheel slightly, they will slide in, but the mark is no longer visable! Distributor looks basicly at 90 degrees from #1 TDC, but it would seem that either the machined mark is off, or something else is very wrong here! I have the nuts, and the slotted head screws backed out all the way! They wont go any more! I'm worried they are pitted or something, and wont come out! What do I do! I have to button up this valve cover so it doesn't get dirty, but I feel like I'm so close to getting this done! Really want to have all 4 cylinders adjusted and the car down off the jack stands by tonight. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:16 AM |
