Squealing in the Dizzy, Help with noise from the Dizzy?? |
lvnzdrm |
Nov 23 2013, 07:55 AM
Member Group: Members Posts: 126 Joined: 30-January 13 From: Virginia Member No.: 15,452 Region Association: MidAtlantic Region |
Hey guys! I have a 1971 914-4. The motor was running fine and only needed a reseal. when the motor went back in it started and ran with no issue for 5 minutes. I shut it off to check oil level and when I started it back up I had a squealing noise. I checked the belt all ok, I felt the dizzy and it was getting hot, the coil (new) was leaking oil, replaced coil, lubed center shaft of dizzy (under felt pad) and greased the cam lob. Squealing noise still there. installed a new dizzy. ( W06 Chinese Knockoff) noise still there. Is there something I am missing? I have search all around and can not find a solution I have not already tried. Frustrated!! Jon see attached video
Attached File(s) IMG_6553.MOV ( 2.75mb ) Number of downloads: 75 |
Lo-Fi Version | Time is now: 27th May 2024 - 11:27 AM |
