Introduction, new 914/4 owner |
Seabird |
Nov 23 2013, 02:49 PM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
Afternoon everyone!
Yesterday I purchased my first 914/4! Just got back this afternoon for the long tow home. I pulled a regular Peter Egan; driving 8 hours across at least one time zone to drag a forgotten toy out from someone else's over crowed garage! Here she is: (IMG:http://www.914world.com/bbs2/uploads_offsite/dl.dropboxusercontent.com-16683-1385392013.1.jpg) One of the PO's started a race car transformation on her a number of years back, had one outing on the track, and then it went into storage. A lot of the race items are out of certification which is fine as I am not going racing soon. The motor has had some work done to it (PO claimed 130 at the wheels) and she has been lightened quite a bit (again PO claimed 1735#s). The PO claimed it to be an LE. Apparently they are fairly rare. Shame that it was hacked up to make into a race car. The chassis is straight and solid. Some minor surface rust in the wheel wells. The battery hole is rock solid. And there is a real nice roll cage welded in. The brakes and suspension have had some major work too! 911 brakes and koni adjust able shocks front and rear. There are a couple of items that are a little annoying... The biggest one is the front trunk has a gaping hole in the center. My brother said thats where the factory a/c would have been installed (IMG:style_emoticons/default/confused24.gif) I will need to find someone parting out a car and fill this. Also someone bugger up the carb linkage. 1/2" balled end on the hex rod is bent something nasty. Will need to find one of those. I bought her with the intent of using her for DE and maybe eventually going vintage racing. I have been using a big block e30, 3.5L m30, for DE with NASA but I wanted to get into something a little older and lighter; I think I succeeded! (IMG:style_emoticons/default/biggrin.gif) First thing I did when I got it home was to drain the fuel and add fresh gas and a new fuel filter. With fresh gas in the system I was able to get her cranked up and running. On a high idle she will stay running but when off the throttle she conchs out. I order a set of carb rebuild kits. I am sure 5 years of sitting in a garage did in the accelerator pumps and floats and jets and...well then need to get rebuild. |
914itis |
Nov 23 2013, 03:01 PM
Randal |
Nov 23 2013, 04:37 PM
And welcome to The Paddock as well. Nothing like the handling of a 4. (IMG:style_emoticons/default/biggrin.gif) |
Jetsetsurfshop |
Nov 23 2013, 07:16 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Seabird,
I've been doing DE with NASA for about two years. Most track time at Sebring. Maybe we know each other. Here's my car. Attached thumbnail(s) |
Seabird |
Nov 23 2013, 07:58 PM
Shane,
I can't recall seeing a 914 in the HPDE sessions this year. I did two of the three Sebring events too. I usually pit with the Spec e30s by 17; its a little out of the way. I'll be sure to find you next time though! Have you found you need to run an oil cooler for track work at Sebring? |
Jetsetsurfshop |
Nov 23 2013, 09:10 PM
Shane, I can't recall seeing a 914 in the HPDE sessions this year. I did two of the three Sebring events too. I usually pit with the Spec e30s by 17; its a little out of the way. I'll be sure to find you next time though! Have you found you need to run an oil cooler for track work at Sebring? I'm installing an external oil cooler now. I was running blind before. No oil temp,oil pressure, or A/F Gauge. Live and learn. I think you said 130hp at the tires? I would consider an external oil cooler. BAT out of Tampa has some great stuff. I'm mounting it under the truck with a put thru fan. I also made a small shroud to force air thru it. There's tons of oil cooler chatter in here with a bunch of great ideas. Someone else will post up a link I bet. When do you think you'll be track ready? Shane |
Seabird |
Nov 23 2013, 09:29 PM
I'm installing an external oil cooler now. I was running blind before. No oil temp,oil pressure, or A/F Gauge. Live and learn. I think you said 130hp at the tires? I would consider an external oil cooler. BAT out of Tampa has some great stuff. I'm mounting it under the truck with a put thru fan. I also made a small shroud to force air thru it. There's tons of oil cooler chatter in here with a bunch of great ideas. Someone else will post up a link I bet. When do you think you'll be track ready? Shane Yeah I have been reading up on the coolers. I will probably do an under rear trunk as well. There is a kit called Derale that I might try just to keep cost down. A/F gauge is a must for tuning the webers. Big oil pressure light on dash. I want to get some kind of silencer for the exhaust, its just open right now. Need to do brake fluid and pads...tires.... mount a different seat to give me a little more head room. I don't know how anyone over 5'11'' can fit legally; I am borderline. There is a bunch of little things. The car has not been run in 5 years. I would like to be ready for the first event of the new year but until I get some of the basics like running its hard to estimate. Ill check out BAT, thanks! Miguel |
nolift914 |
Nov 24 2013, 03:05 PM
Autoxer Group: Members Posts: 183 Joined: 24-May 09 From: Rockaway Beach NY Member No.: 10,399 Region Association: None |
(IMG:style_emoticons/default/welcome.png) and the Paddock
ConeDodger |
Nov 25 2013, 11:24 PM
Apex killer! Group: Members Posts: 23,569 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
If it is indeed an LE, Jeff Bowlsby will want to add the VIN to the LE registry. You should also add it to the owners VIN#... (IMG:style_emoticons/default/biggrin.gif)
Seabird |
Nov 26 2013, 04:57 AM
If it is indeed an LE, Jeff Bowlsby will want to add the VIN to the LE registry. You should also add it to the owners VIN#... (IMG:style_emoticons/default/biggrin.gif) The PO did not provide a COA. I am going to wait on getting one, need to spend the moneys on getting it track ready. When I do get a COA confirming that it is an LE I will submit it to the registry. Some times when I look at it I think it is a real LE and sometimes I look at it and think no its been made to look like an LE. The bottom valance is certianly not an original LE valance as it has a raw backside (the factory one would have been smooth on all sides according to Bowlsby's site). It does have on of the lower valance brackets though. (IMG:style_emoticons/default/confused24.gif) I dont know if it is or not. Doesn't really matter. So much of the original equipment is missing that it would cost more to return it to stock form that it is worth on the market. I am going to enjoy it for what it is today. Miguel |
Randal |
Nov 26 2013, 10:05 AM
About that oil cooler. When I bought my car the PO in Carson City, Nev. had installed an oil cooler, with a 600cfm fan underneath the engine cover. Like one unit.
It actually worked good and I ran that configuration at Button Willow when it was HOT. Never had high oil temperatures, but the heat coming into the compartment wilted everything. So changed the configuration a bit (see the link) and had it suck the air out of the engine compartment and it worked good. The revised configuration had 1600cfm fan. Sold it to Dan Thompson who then installed it in his front trunk exiting downward. There are pictures here somewhere... More here: http://www.914world.com/bbs2/index.php?sho...ic=8146&hl= |
Randal |
Nov 26 2013, 10:11 AM
About that oil cooler. When I bought my car the PO in Carson City, Nev. had installed an oil cooler, with a big fan underneath the engine cover. Like one unit. It actually worked good and I ran that configuration at Button Willow when it was HOT. Never had high oil temperatures. Sold it to Dan Thompson who then installed it in his front trunk exiting downward. There are pictures here somewhere... The magic of search.. http://www.914world.com/bbs2/index.php?sho...p;hl=oil+cooler Forgot how nice that unit was. We build a flat plate that the cooler was attached to, then mounted the fan on a round aluminum piece that acted like a shroud. I kind of like where Dan put it, but it also worked great mounted under the engine cover, with the shroud configuration and bigger fan. |
ConeDodger |
Nov 26 2013, 11:23 AM
If it is indeed an LE, Jeff Bowlsby will want to add the VIN to the LE registry. You should also add it to the owners VIN#... (IMG:style_emoticons/default/biggrin.gif) The PO did not provide a COA. I am going to wait on getting one, need to spend the moneys on getting it track ready. When I do get a COA confirming that it is an LE I will submit it to the registry. Some times when I look at it I think it is a real LE and sometimes I look at it and think no its been made to look like an LE. The bottom valance is certianly not an original LE valance as it has a raw backside (the factory one would have been smooth on all sides according to Bowlsby's site). It does have on of the lower valance brackets though. (IMG:style_emoticons/default/confused24.gif) I dont know if it is or not. Doesn't really matter. So much of the original equipment is missing that it would cost more to return it to stock form that it is worth on the market. I am going to enjoy it for what it is today. Miguel Miguel, Jeff won't need a COA to tell. If its within a range of VIN numbers and has certain paint codes and other elements, it's likely an LE... |
Seabird |
Nov 26 2013, 02:00 PM
The magic of search.. http://www.914world.com/bbs2/index.php?sho...p;hl=oil+cooler Forgot how nice that unit was. We build a flat plate that the cooler was attached to, then mounted the fan on a round aluminum piece that acted like a shroud. I kind of like where Dan put it, but it also worked great mounted under the engine cover, with the shroud configuration and bigger fan. Thanks for the ideas Randal! I am leaning towards a rear mounted solution to keep the front free for a fuel cell when the time comes. As a six is not on the horizon I probably will not have the need to disturb the front of the car with an oil cooler. I have a couple of oil cooler questions though, whats the deal with the stock one? Does this just get abandoned when a remote is added? If so should it be removed? And lastly, is there a reason folks aren't make use of the heater ducts to pipe fresh air from the front to the rear? Seems like half the work is already done! Pull the air from right in front of the windshield where the pressure increases and push it back to either side of the engine right onto the heads! Use a little cowling like this and you'll get a ton of air. Jeep accessories Just some thoughts Miguel |
Seabird |
Nov 26 2013, 02:03 PM
budk |
Dec 1 2013, 07:22 AM
Yes! It's a Bumblebee! Group: Members Posts: 677 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
Miguel, Jeff won't need a COA to tell. If its within a range of VIN numbers and has certain paint codes and other elements, it's likely an LE... I'll reach out to him. I do know the vin number is within the range for an LE. Miguel What is the VIN ? Color of headlight motors? Lots of clues to look for. |
Jetsetsurfshop |
Dec 2 2013, 07:36 PM
QUOTE And lastly, is there a reason folks aren't make use of the heater ducts to pipe fresh air from the front to the rear? Seems like half the work is already done! Pull the air from right in front of the windshield where the pressure increases and push it back to either side of the engine right onto the heads! Use a little cowling like this and you'll get a ton of air. Jeep accessories Just some thoughts Miguel I've always thought this was a good idea. What are you planing to do with the "fresh air"? What about NACA ducts on the hood? |
brant |
Dec 2 2013, 09:51 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
naca ducts on the hood wouldn't be legal in my vintage club...
carr914 |
Dec 3 2013, 05:19 AM
Racer from Birth Group: Members Posts: 118,258 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Seabird, you will need a Cooler for Sebring. BAT is in Sarasota.
Are you here in Florida? West Coast? (IMG:style_emoticons/default/welcome.png) |
bulitt |
Dec 3 2013, 08:08 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
If you decide not to go with a front cooler this should close the AC hole in the trunk floor-
Restoration Design |
Lo-Fi Version | Time is now: 29th April 2024 - 04:08 PM |
