WTB wires from harness-Found, sell me your old messed up wires |
worn |
Nov 26 2013, 01:54 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I am looking for correct colored wires for my 6 conversion. Best bet would be someone's old harness with a lot of the ends missing, burned or otherwise made useless. Something that you would never use as a harness, but has lots of wire left in it. The wires will be used for gauges and relays, so I don't need the heavy alternator or starter hunks.
I am not looking for a box of 6 inch wire scraps, longer is better, but it doesn't have to be something great. It will be cut up so that I get the colors right. PM or email me if you have something. Of course a pic is worth a lot. Thanks |
worn |
Nov 29 2013, 07:19 PM
I am looking for correct colored wires for my 6 conversion. Best bet would be someone's old harness with a lot of the ends missing, burned or otherwise made useless. Something that you would never use as a harness, but has lots of wire left in it. The wires will be used for gauges and relays, so I don't need the heavy alternator or starter hunks. I am not looking for a box of 6 inch wire scraps, longer is better, but it doesn't have to be something great. It will be cut up so that I get the colors right. PM or email me if you have something. Of course a pic is worth a lot. Thanks Looks like i have what i want. Thanks folks. |
Lo-Fi Version | Time is now: 16th May 2024 - 06:50 PM |
