Trans upgrade?, What are some good trans swaps? |
Pdr1787 |
Nov 26 2013, 06:33 PM
Sneaky Pete Group: Members Posts: 55 Joined: 8-September 09 From: Lakewood, California Member No.: 10,779 Region Association: Southern California |
Builing a 2.0l cammed port and polished with some dellortos. maybe thinking of a small turbo too but i have a tail shifter trans. I want to definitely replace it with something that will give me some smooth crisp shifts. any ideas? side shift, 930/915? (IMG:style_emoticons/default/type.gif)
Pdr1787 |
Nov 26 2013, 06:34 PM
Builing a 2.0l cammed port and polished with some dellortos. maybe thinking of a small turbo too but i have a tail shifter trans. I want to definitely replace it with something that will give me some smooth crisp shifts. any ideas? side shift, 930/915? (IMG:style_emoticons/default/type.gif) Building*.... |
Nov 26 2013, 06:43 PM
A solid side-shift 901 will be plenty for what you're building. I'm running one behind my 3.6L and it has been holding up just fine for the last 6+ years.
(IMG:style_emoticons/default/smile.gif) |
Dr Evil |
Nov 26 2013, 08:13 PM
(IMG:style_emoticons/default/agree.gif) Rebuild it for better performance, though. A clapped out, used box will likely deliver frustration.
Mike Bellis |
Nov 26 2013, 08:42 PM
For power levels of your T4 your 901 is fine.
For "Crisp Shifts", good luck. A 40 year old transmission does not shift like a modern car. If you want crisp shifts and a mid engine tranny that can mount a starter, be prepared to spend big money... (IMG:style_emoticons/default/sad.gif) http://mendeolamotors.com/trans-proto/inde...2&Itemid=65 |
Eric_Shea |
Nov 26 2013, 09:05 PM
901 side shift with updated linkage below (spherical firewall bushing, u-joints and multiple bronze bushings at the side shift console). Use a simple throw reduction for the shifter and call it a day.
Dr Evil |
Nov 26 2013, 09:18 PM
(IMG:style_emoticons/default/agree.gif) I had a rebuilt with stock, new bushings and a short shift and it would shock people how well it operated. Cheap and easy compared to other options.
Bills914-4 |
Nov 27 2013, 05:54 AM
Member Group: Members Posts: 310 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
901 side shift with updated linkage below (spherical firewall bushing, u-joints and multiple bronze bushings at the side shift console). Use a simple throw reduction for the shifter and call it a day. Here's a few pic's of my modifications (IMG:style_emoticons/default/smile.gif) plus a J West shifter , Bill D. |
ww914 |
Nov 27 2013, 06:28 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
901 side shift with updated linkage below (spherical firewall bushing, u-joints and multiple bronze bushings at the side shift console). Use a simple throw reduction for the shifter and call it a day. Eric When you say "updated linkage below", what are you referring to? Do you sell these goodies? |
Nov 27 2013, 07:17 AM
901 side shift with updated linkage below (spherical firewall bushing, u-joints and multiple bronze bushings at the side shift console). Use a simple throw reduction for the shifter and call it a day. Eric When you say "updated linkage below", what are you referring to? Do you sell these goodies? JWest used to sell a linkage kit for 914's. They stopped (still sell a renshifter) and Chris Folley at tangerine racing now makes a really nice one. http://www.tangerineracing.com/transmission.htm |
Eric_Shea |
Nov 27 2013, 07:28 AM
I'm using the old j west system below. Basically what Chris is selling in the link Mark posted. Similar to what Bill posted above. Worth every penny Chris is charging.
The linkage below is where all of the slop is. The short shifters are basically reduction devices. I wanted a stock look and a hand throttle so I retained the stock shifter and used the simplest of the reduction devices. The Weltmeister. |
gothspeed |
Nov 27 2013, 10:05 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Eric_Shea |
Nov 27 2013, 12:50 PM
Bill, I had one issue with my JWest install. The side shift console bushing plate is aluminum and would bind as I torqued the fasteners to spec. The unit cones with shims to accommodate this flex but it took a "lot" of trial and error and even shims cut in 1/2.
Is your bushing plate steel or aluminum? I was thinking steel wouldn't flex and i need to put another one of these together. Sorry for the (IMG:style_emoticons/default/hijacked.gif) |
jimkelly |
Nov 27 2013, 01:50 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I do not know that anyone has ever installed anything other than a 901 behind a type4 ???
KEP offers one kit for the type4 engine. I wonder if a suby awd trans converted to 2wd could even feasibly be coupled to a type4 ?? I guess one would have to ask KEP. http://www.kennedyenginc.com/Pages/EngineOptionList4cyl.aspx |
ChrisFoley |
Nov 27 2013, 02:45 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Is your bushing plate steel or aluminum? I was thinking steel wouldn't flex and i need to put another one of these together. Our aluminum bushing block doesn't flex. (IMG:style_emoticons/default/smile.gif) |
mittelmotor |
Nov 27 2013, 03:55 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
My Dr. Evil-rebuilt 901 is holding up great paired with a stock LS1 V-8. I never abuse it with drop-clutch starts, which I'm sure helps!
Racer Chris, I am VERY tempted by your shift upgrade kit. My side shifter has pretty good action already (fresh plastic stock bushings), but it could be further optimized. |
Pdr1787 |
Nov 27 2013, 04:37 PM
Thanks for the replies guys! looks like I'm going to look for a sideshiifting trans. I'm going to have to look for a new motor mount brace too. What about the linkage at the firewall. I know its different right. what am I going to have to do there? (IMG:style_emoticons/default/confused24.gif)
jimkelly |
Nov 27 2013, 04:46 PM
there are several online parts diagrams
http://www.porsche.com/usa/accessoriesands...partscatalogue/ http://www.autoatlanta.com/porsche-parts/p...e_914_parts.php but you can't use any linkage from tail shift for side shift. you'll need a shifter, tunnel rod, engine bay rod, etc. you can use whatever exhaust you have (1.7/1.8/2.0) on your 2.0 but if you decide you want 2.0 style exhaust, you need to change everything there too. are you doing fuel injection or carbs? what cam you using? |
gothspeed |
Nov 27 2013, 05:50 PM
Is your bushing plate steel or aluminum? I was thinking steel wouldn't flex and i need to put another one of these together. Our aluminum bushing block doesn't flex. (IMG:style_emoticons/default/smile.gif) Nice design, that added web will indeed make it more rigid. (IMG:style_emoticons/default/smile.gif) |
Bills914-4 |
Nov 30 2013, 09:52 AM
Bill, I had one issue with my JWest install. The side shift console bushing plate is aluminum and would bind as I torqued the fasteners to spec. The unit cones with shims to accommodate this flex but it took a "lot" of trial and error and even shims cut in 1/2. Is your bushing plate steel or aluminum? I was thinking steel wouldn't flex and i need to put another one of these together. Sorry for the (IMG:style_emoticons/default/hijacked.gif) Eric, I machined that from a solid block of steel ( I won't do that again ) (IMG:style_emoticons/default/biggrin.gif) , I think I would bend a piece of 1/4-5/16 strap metal (flat stock) with a torch ,give enough length so that you can put the cover on, I machined mine then mounted it 3 bolts , I scribed a circle through the console tab with out the bushing ,then I removed the bracket and put hole in (that way it slides through the original console ear) I then put the hole on the other side , I used two original console bushings to make it easier in the future to find and change (IMG:style_emoticons/default/biggrin.gif) , I hope this helps Bill D. here's a couple more pic's |
Lo-Fi Version | Time is now: 15th May 2024 - 01:20 PM |
