QUOTE(Eric_Shea @ Nov 27 2013, 01:50 PM)
Bill, I had one issue with my JWest install. The side shift console bushing plate is aluminum and would bind as I torqued the fasteners to spec. The unit cones with shims to accommodate this flex but it took a "lot" of trial and error and even shims cut in 1/2.
Is your bushing plate steel or aluminum? I was thinking steel wouldn't flex and i need to put another one of these together.
Sorry for the
Eric, I machined that from a solid block of steel ( I won't do that again )
, I think I would bend a piece of 1/4-5/16 strap metal (flat stock) with a torch ,give enough length so that you can put the cover on, I machined mine then mounted it 3 bolts , I scribed a circle through the console tab with out the bushing ,then I removed the bracket and put hole in (that way it slides through the original console ear) I then put the hole on the other side , I used two original console bushings to make it easier in the future to find and change
, I hope this helps Bill D.
here's a couple more pic's
Click to view attachmentClick to view attachment
