914-6 Engine Mounts, similar to PMS, but stronger and less expensive |
naro914 |
Dec 3 2013, 05:41 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Not sure if this should go here, but figured it would be the least offensive to the moderators...
We've developed a weld-in 914-6 mount that's similar in design to the Patrick Motorsports mount, but has some improvements with strengthening and angles. I personally run these on both of our cars: Huey with a stock 3.2 liter Papa Smurf with a full out 350 hp, 275 lb/ft torque, twin plugged 3.2 liter No problems, no issues, easily handles the power and makes installing the engine actually really easy! Price is $375 plus shipping (usually about $25) |
naro914 |
Jan 9 2014, 10:22 AM
JR
I don't see a problem with using the mount for a stock 3.6 liter, but I will be honest and say that we have not done that yet. Dimensionally, it is the same at the Patrick mount that they do use for 3.6 installs, so I would think it would be fine. You do get some engine vibration felt through the car as yes, the bushings are fairly stiff. The problem with using softer bushings is that the through bolt is basically resting on the bushing, so if it was soft and pliable, it would compress and allow the entire mount to 'sag'...if that makes any sense? |
-JR- |
Jan 10 2014, 01:54 AM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
Super thanks!
Not quite ready to move ahead yet with the mount as I haven't started the project yet. But I'm very interested in this mount when I'm ready. Probably talk to you again in another two-three months for one. Thanks again. JR I don't see a problem with using the mount for a stock 3.6 liter, but I will be honest and say that we have not done that yet. Dimensionally, it is the same at the Patrick mount that they do use for 3.6 installs, so I would think it would be fine. You do get some engine vibration felt through the car as yes, the bushings are fairly stiff. The problem with using softer bushings is that the through bolt is basically resting on the bushing, so if it was soft and pliable, it would compress and allow the entire mount to 'sag'...if that makes any sense? |
Lo-Fi Version | Time is now: 18th May 2024 - 06:32 PM |
