> building a megaphone bracket, any suggestions
vintage914racer
post Dec 28 2004, 05:35 PM
Since tomorrow is my day off I think I might try to make a megaphone bracket for my car. Does anyone have any suggestions on how to do it? I probably won't get it completely finished since i do not have a welder, unless someone can come up with a way to do it without a welder. I guess I am planning on bending a small diameter tube and attaching it to the end of the tranny and then figure out some way to attach the megaphones to that. Suggestions?
Replies(1 - 3)
Trekkor
post Dec 28 2004, 07:07 PM
I do things...
the 2.0 hanger works good as is...
KT
machina
post Dec 28 2004, 08:56 PM
I shot this when I was at Orbit Racing couple years ago. It is their RSR LeMans Car.
I like the way the bracket captures the megaphone from underneath and then the top is held in place with a spring.
Something like this would look awsome on a 914.
I only have 1 muffler with a crappy FLAPS hangar but I'd like to fab something like this.
campbellcj
post Dec 29 2004, 12:01 AM
I can't Re Member
I use the regular 2.0 muffler bracket as I have the "street length" Bursch headers so the flanges are in the normal heat exchanger location.
I have a European Racing Headers (George Narbel) megaphone bracket stashed away in the garage. It's fairly crude and is basically a rectangle of sheet metal that bolts to the trans as usual, then has two tubes, perhaps 5/8-3/4" that extend down diagonally to each pipe. These are welded to semi-circular sheet metal pieces that are then clamped to the megaphones with "hose clamps" or equivalent.
Frankly I can't picture building one w/o welding. I'm sure it -could- be done, but the time involved might be better spent on other projects and keep in mind that this thing needs to endure high heat, vibration, and potentially weather/road hazard exposure.
- Lo-Fi Version Time is now: 8th June 2026 - 02:25 PM
