Momo steering wheel, Should I get a 350mm or 320mm diameter? |
Stephane |
Dec 28 2004, 07:07 PM
Newbie Group: Members Posts: 45 Joined: 13-February 04 From: New Brunswick, Canada Member No.: 1,653 |
I need your opinion , should I get a 350mm or 320mm diameter Monte Carlo? Do I need the Momo hub or would my current Racemark hub work?
thanks Stephane |
Dec 28 2004, 07:09 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
the 320 seems too small for me. i love the 350 i have ... hmmm, maybe it's the 225 front tires? dunno, the 350 gives me more "leverage" and is still much smaller than stock ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Jeroen |
Dec 28 2004, 07:18 PM
depends how much you work out in the gym (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
but seriously, just get a 350mm |
lapuwali |
Dec 28 2004, 07:30 PM
The 350 only blocks the gauges a bit. The 320 blocks them a lot...
Aaron Cox |
Dec 28 2004, 07:35 PM
love my 350 prototipo (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Stephane |
Dec 28 2004, 07:50 PM
Can anyone tell me the bolt circle dimension on a Momo
steering wheel? |
campbellcj |
Dec 28 2004, 11:27 PM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I'm pretty sure the Racemark hub does not work. You need a Momo/Sparco type of hub.
I had a 320mm Monte Carlo a few years ago and I liked the steering wheel a lot for its quick ratio and thigh clearance, but you really can't see the dash at all! (IMG:http://www.nosubstitute.org/914/gallery_old/dash.jpg) Now I have a 350mm (or 360) Personal Fittipaldi which is my favorite steering wheel thus far. |
dinomium |
Dec 29 2004, 12:37 AM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
I find that the Momo Top Power 350mm is the best for sitting in my garage and making porsche noises while I pretend to drive. From what I can remember, it was great to drive with too
You will need the correct Momo hub... Get the spacer kit too, otherwise you will be signaling and wiping your windshileld when you turn. Your hands will hit the stalks. |
Curvie Roadlover |
Dec 29 2004, 05:05 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) |
aircooledboy |
Dec 29 2004, 11:37 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
I don't know what you are planning to use the car for, but I just thought I would throw this out there: I have a perfect 350mm Momo sitting on my tool chest because it was impossible to see the speedo with that wheel. I could turn the speedo itself so I could either see up to 25 mph, then again at 90+mph, or up to about 45 mph, then not again until 120. Talking to others, it sounds like the extent of the obstruction depends mostly on the height of the driver. I am about 5'11", and as much as I liked the look and feel of the wheel, it was just impossible to use it on the street for me. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Series9 |
Dec 29 2004, 02:27 PM
I have 320mm Momos in all my cars. Once I used one, I could never go back. I just turned the gauges so I could see them.
Dec 29 2004, 02:48 PM
yupp, i turned the tach 180 deg upside down and switched the blinker indicators. took a couple of days to get use to it but now it works great. i also turned the speedo so i can easily see from about ~20 to ~100 (i have a 944 speedo) ... the rest of the gauges are fine, but i have a 911 dash so your results may differ ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
Stephane |
Dec 29 2004, 05:38 PM
Thanks for your input everyone! It's much appreciated !!
Stephane |
soloracer |
Dec 29 2004, 06:13 PM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
I installed a quick release system on my car and have no need for the spacers. The quick release was something like $100 US. I have a Momo hub and 350mm Monte Carlo wheel. I can take measurements and pictures if you like.
Stephane |
Dec 29 2004, 07:27 PM
Thanks Solo, I went ahead & ordered the wheel & the hub tonight. Gonna try to go without the spacer for now.
I'll see how that goes. thanks Stephane |
TheCabinetmaker |
Dec 29 2004, 07:49 PM
Stephane, you have a PM
Elliot_Cannon |
Dec 29 2004, 11:01 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
I didn't use a spacer cause I like the steering wheel far away as possible. I turned my speedo but the cable comes out of it at an angle. When I turned it the cable came out at a more acute angle and eventually broke the cable. My hand kept hitting the windshield wiper lever so I used a hack saw blade and shortened it up a bit.
cheers, Elliot |
Gint |
Dec 29 2004, 11:30 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
320MM Momo Raceline. I love it. Yeah, it blocks the gauges. Who cares!?!
Jeroen |
Dec 31 2004, 01:26 PM
70 mm |
Lo-Fi Version | Time is now: 29th April 2024 - 04:17 PM |
