Stephane
Dec 28 2004, 07:07 PM
I need your opinion , should I get a 350mm or 320mm diameter Monte Carlo? Do I need the Momo hub or would my current Racemark hub work?
thanks
Stephane
Dec 28 2004, 07:09 PM
QUOTE (Stephane @ Dec 28 2004, 05:07 PM) |
I need your opinion , should I get a 350mm or 320mm diameter Monte Carlo? Do I need the Momo hub or would my current Racemark hub work? |
the 320 seems too small for me. i love the 350 i have ...
hmmm, maybe it's the 225 front tires? dunno, the 350 gives me more "leverage" and is still much smaller than stock ...
Andy
Jeroen
Dec 28 2004, 07:18 PM
depends how much you work out in the gym
but seriously, just get a 350mm
lapuwali
Dec 28 2004, 07:30 PM
The 350 only blocks the gauges a bit. The 320 blocks them a lot...
Aaron Cox
Dec 28 2004, 07:35 PM
QUOTE (Jeroen @ Dec 28 2004, 06:18 PM) |
but seriously, just get a 350mm |
love my 350 prototipo
Stephane
Dec 28 2004, 07:50 PM
Can anyone tell me the bolt circle dimension on a Momo
steering wheel?
campbellcj
Dec 28 2004, 11:27 PM
I'm pretty sure the Racemark hub does not work. You need a Momo/Sparco type of hub.
I had a 320mm Monte Carlo a few years ago and I liked the steering wheel a lot for its quick ratio and thigh clearance, but you really can't see the dash at all!
Now I have a 350mm (or 360) Personal Fittipaldi which is my favorite steering wheel thus far.
dinomium
Dec 29 2004, 12:37 AM
I find that the Momo Top Power 350mm is the best for sitting in my garage and making porsche noises while I pretend to drive. From what I can remember, it was great to drive with too
You will need the correct Momo hub... Get the spacer kit too, otherwise you will be signaling and wiping your windshileld when you turn. Your hands will hit the stalks.
Curvie Roadlover
Dec 29 2004, 05:05 AM
QUOTE (dinomium @ Dec 29 2004, 01:37 AM) |
Get the spacer kit too, otherwise you will be signaling and wiping your windshileld when you turn. Your hands will hit the stalks. |
aircooledboy
Dec 29 2004, 11:37 AM
I don't know what you are planning to use the car for, but I just thought I would throw this out there: I have a perfect 350mm Momo sitting on my tool chest because it was impossible to see the speedo with that wheel. I could turn the speedo itself so I could either see up to 25 mph, then again at 90+mph, or up to about 45 mph, then not again until 120. Talking to others, it sounds like the extent of the obstruction depends mostly on the height of the driver. I am about 5'11", and as much as I liked the look and feel of the wheel, it was just impossible to use it on the street for me.
Series9
Dec 29 2004, 02:27 PM
I have 320mm Momos in all my cars. Once I used one, I could never go back. I just turned the gauges so I could see them.
Dec 29 2004, 02:48 PM
QUOTE (aircooledboy @ Dec 29 2004, 09:37 AM) |
I could turn the speedo itself so I could either see up to 25 mph, then again at 90+mph, or up to about 45 mph, then not again until 120. |
yupp, i turned the tach 180 deg upside down and switched the blinker indicators. took a couple of days to get use to it but now it works great.
i also turned the speedo so i can easily see from about ~20 to ~100 (i have a 944 speedo) ...
the rest of the gauges are fine, but i have a 911 dash so your results may differ ...
Andy
Stephane
Dec 29 2004, 05:38 PM
Thanks for your input everyone! It's much appreciated !!
Stephane
soloracer
Dec 29 2004, 06:13 PM
I installed a quick release system on my car and have no need for the spacers. The quick release was something like $100 US. I have a Momo hub and 350mm Monte Carlo wheel. I can take measurements and pictures if you like.
Stephane
Dec 29 2004, 07:27 PM
Thanks Solo, I went ahead & ordered the wheel & the hub tonight. Gonna try to go without the spacer for now.
I'll see how that goes.
thanks
Stephane
TheCabinetmaker
Dec 29 2004, 07:49 PM
Stephane, you have a PM
Elliot_Cannon
Dec 29 2004, 11:01 PM
I didn't use a spacer cause I like the steering wheel far away as possible. I turned my speedo but the cable comes out of it at an angle. When I turned it the cable came out at a more acute angle and eventually broke the cable. My hand kept hitting the windshield wiper lever so I used a hack saw blade and shortened it up a bit.
cheers, Elliot
Gint
Dec 29 2004, 11:30 PM
320MM Momo Raceline. I love it. Yeah, it blocks the gauges. Who cares!?!
Jeroen
Dec 31 2004, 01:26 PM
QUOTE (Stephane @ Dec 29 2004, 03:50 AM) |
Can anyone tell me the bolt circle dimension on a Momo steering wheel? |
70 mm
