WTB French rear light lens, Frenchie... |
porbmw |
Dec 7 2013, 11:56 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
So....
Have a NOS French left lens....and a pretty crappy, repaired right side... Doesn't look so great, one side mighty fine, other side not.... Anyone have a really clean Frenchie, right side Thanks Paul |
carr914 |
Dec 8 2013, 06:34 AM
Racer from Birth Group: Members Posts: 118,626 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Next thing you know, you will be liking Girls with Hairy ArmPits & Legs! (IMG:style_emoticons/default/biggrin.gif)
gms |
Dec 8 2013, 11:43 AM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I have a right with a small crack
MikeInMunich |
Dec 8 2013, 12:11 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
porbmw |
Dec 9 2013, 12:56 AM
Next thing you know, you will be liking Girls with Hairy ArmPits & Legs! (IMG:style_emoticons/default/biggrin.gif) Viva la difference! (IMG:style_emoticons/default/biggrin.gif) |
porbmw |
Dec 9 2013, 12:59 AM
I have a right with a small crack Hi Glenn Thanks... Let me scrutinize mine a bit...it doesn't have any cracks, but has some crazing...and was repaired at a seam...so not sure which is better/worse....Problem is anything that is not spot on clean shows up when the other side is NOS Paul |
porbmw |
Dec 9 2013, 01:03 AM
Hi Mike Thanks for the heads up...I missed the auction.....BUT....I actually had seen that one, and decided against it... There seems to be something strange about that one...if you note the far side/porton...I think the owner darkened up the one portion of the lens...if you look at his other lens, he seems to have done some different mod on that one. But thanks, I'm going to have to keep watching the French ebay. Don't think there are many teeners in France, so will be patient. Paul |
gms |
Dec 9 2013, 10:37 AM
....Problem is anything that is not spot on clean shows up when the other side is NOS Simple solution...just rough up the NOS side (IMG:style_emoticons/default/confused24.gif) |
MikeInMunich |
Dec 9 2013, 10:42 AM
Hi Mike Thanks for the heads up...I missed the auction.....BUT....I actually had seen that one, and decided against it... There seems to be something strange about that one...if you note the far side/porton...I think the owner darkened up the one portion of the lens...if you look at his other lens, he seems to have done some different mod on that one. But thanks, I'm going to have to keep watching the French ebay. Don't think there are many teeners in France, so will be patient. Paul No worries Paul. I just bought this the other day, as I am sending a package to CA anyway. Figured someone over there could use it soon enough. http://www.ebay.de/itm/141121795212?ssPage...984.m1439.l2649 Mike in Munich |
porbmw |
Dec 9 2013, 10:38 PM
....Problem is anything that is not spot on clean shows up when the other side is NOS Simple solution...just rough up the NOS side (IMG:style_emoticons/default/confused24.gif) Phtttp! (IMG:style_emoticons/default/dry.gif) No shortage of really good, helpful advice in this group (IMG:style_emoticons/default/evilgrin.gif) Actually, thanks for letting me know....I"ll experiment with what I"ve got, and may get back to you on that one. Paul |
Lo-Fi Version | Time is now: 16th May 2024 - 01:56 AM |
