Where can I get tires now? |
Jonas |
Dec 9 2013, 04:54 PM
Newbie Group: Members Posts: 4 Joined: 12-June 06 From: Huntington Beach Member No.: 6,211 |
This may sound stupid, but I can't find any good tires anymore for my 15x7/15x8 (I think that is correct width) 5-lug wheels. I've checked all the tire shops around.
Unless I want to get cheap all-weather tires, I don't know what to get. My last set were Dunlop SP8000's. Any recommendations? |
Andyrew |
Dec 9 2013, 05:03 PM
discounttiredirect.com
or Tirerack.com I typically go through both and price compare similar tire. |
Dec 9 2013, 05:55 PM
Please update this thread.....
I wanted to stick with 15 inch wheels for my flared car, but if I cannot get a decent tire, there is no point. |
AfricanHijinx |
Dec 9 2013, 05:59 PM
Member Group: Members Posts: 132 Joined: 12-April 11 From: Snohomish WA Member No.: 12,928 Region Association: Pacific Northwest |
americas tire has contis, I like them
Spoke |
Dec 9 2013, 06:00 PM
Tirerack and Discount tire usually have local installers and will drop ship the tires to that installer. Check their websites for installers close to you.
Discount Tire 225/50/15 for $79 |
ruby914 |
Dec 9 2013, 06:09 PM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I had the same problem with my 16x7/16x8. Mostly the 8s.
Biggest problem was finding something in a low profile tire for the rear. I ended up getting an old, unused set. Don't know what I will do next time (IMG:style_emoticons/default/confused24.gif) Good luck. |
Dec 9 2013, 07:02 PM
All the bigger brands still have tires in 225/50x15:
http://www.tirerack.com/tires/TireSearchRe...amp;diameter=15 That's what i'm running for street tires ... (IMG:style_emoticons/default/shades.gif) |
Dec 9 2013, 07:04 PM
All the bigger brands still have tires in 225/50x15: http://www.tirerack.com/tires/TireSearchRe...amp;diameter=15 That's what i'm running for street tires ... (IMG:style_emoticons/default/shades.gif) Rim widths? |
Dec 9 2013, 07:07 PM
Rim widths? 7 or 8 just as asked by the OP. The 225 will fit on both. (IMG:style_emoticons/default/idea.gif) |
Dec 9 2013, 07:14 PM
Rim widths? 7 or 8 just as asked by the OP. The 225 will fit on both. (IMG:style_emoticons/default/idea.gif) Sorry, what rims are you running? I recall you were running wider rims? |
Dec 9 2013, 07:17 PM
Rim widths? 7 or 8 just as asked by the OP. The 225 will fit on both. (IMG:style_emoticons/default/idea.gif) Sorry, what rims are you running? I recall you were running wider rims? For the street, i run 7x15 cookie cutters with 225/50 tires. Again, those tires fit both 7" and 8" rims and there is still a healthy choice of tires for that size. If i had to buy new ones right now, i would go with a set of Toyo R888 ... (IMG:style_emoticons/default/shades.gif) |
Woody |
Dec 9 2013, 07:28 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Rim widths? 7 or 8 just as asked by the OP. The 225 will fit on both. (IMG:style_emoticons/default/idea.gif) Sorry, what rims are you running? I recall you were running wider rims? For the street, i run 7x15 cookie cutters with 225/50 tires. Again, those tires fit both 7" and 8" rims and there is still a healthy choice of tires for that size. If i had to buy new ones right now, i would go with a set of Toyo R888 ... (IMG:style_emoticons/default/shades.gif) My street/track wheels are 888s on 15x7 and 15x8 Fuchs. 205/225. Great combo but may be a little more than needed for street use. |
Dec 9 2013, 07:41 PM
Great combo but may be a little more than needed for street use. That's why i didn't recommend them to the OP, but Rich asked specifically. For my car, those would be the ones i would buy right now if i needed new tires. My car. Not yours. Mine. (IMG:style_emoticons/default/rolleyes.gif) |
Dec 9 2013, 09:02 PM
Great combo but may be a little more than needed for street use. That's why i didn't recommend them to the OP, but Rich asked specifically. For my car, those would be the ones i would buy right now if i needed new tires. My car. Not yours. Mine. (IMG:style_emoticons/default/rolleyes.gif) thank you, it was the answer to the question I asked. I am considering having someone make a set of 4 bolt fuch wheels into 8 and 9 inch widths. Seems to be a similar cost for the wheel, when you include all the other 5 bolt parts... Never seen wide 4 bolt fuch wheels before... Rich |
jim_hoyland |
Dec 9 2013, 09:17 PM
Get that VIN ? Group: Members Posts: 9,292 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Hi Jonus,
Try Grand Prix on Newport Blvd between 17th and 18th; ask for Berge, he's really helpful and can fix you up. Gonna put on some new shoes for the Christmas parade ? |
Spoke |
Dec 9 2013, 09:59 PM
Please update this thread..... I wanted to stick with 15 inch wheels for my flared car, but if I cannot get a decent tire, there is no point. I think this is a valid comment. It seems the 15in selection is dwindling. Not that you can't get them but there is less and less demand for them and less and less availability. Consider the 225/50/15 that Sir Andy and I provided links. At Discount Tire there were only 3 hits. In Sir Andy's link the 3 lowest priced street tires were closeouts. The rest (except $281 Pirellis) are autocross/racing tires. If you were to look for 225/50/16 tires for a 7/8 by 16 rim, Discount Tire's selection goes from 3 to 40. At Tirerack, the selection goes from 13 (3 closeouts, one $281 street, rest racing) to 69. You can still get the 15 inch tires but their days are numbered. That's one reason I went with 6x16 and 7x16 on my 914. (IMG:style_emoticons/default/beerchug.gif) |
Dec 9 2013, 10:22 PM
I am considering having someone make a set of 4 bolt fuch wheels into 8 and 9 inch widths. Seems to be a similar cost for the wheel, when you include all the other 5 bolt parts... Never seen wide 4 bolt fuch wheels before... Rich I talked to harvey weidman about getting a set made in 7&8's. I never did follow through after he gave me an estimate. It was a fair price for his outstanding work but more than I felt comfortable spending on a set of wheels. And then I would be limited to small brakes on the front. |
Jonas |
Dec 10 2013, 01:31 AM
Hi Jonus, Try Grand Prix on Newport Blvd between 17th and 18th; ask for Berge, he's really helpful and can fix you up. Gonna put on some new shoes for the Christmas parade ? Hey Jim! Not for the Christmas Parade, but soon anyway! I haven't had any extra money to spend on my car for awhile, so it's pretty much been sitting. Just put in a new battery, still runs great, but it needs some clean up pretty bad. Starting to get some rust around the edges. Just not sure about how to find the time do do everything. But i digress, the tire sizes I bought last time were 205/55-15 & 225/50-15 in Dunlop SP8000. I've just been looking around and can't find anything in that size in a matching set. No luck at Tire Rack, or Goodyear, Americas Tire, or others. I was just curious what the guys with flares are putting on their 15 inch rims these days? I have definitely noticed that 10 years ago, I could find all kinds of 15" performance tires for that size range. Now, nothing! It's all 16, and mostly 17" in anything that isn't a 500 treadwear mud & snow tire. |
Jonas |
Dec 10 2013, 10:44 AM
What about these? Sizes are close:
Dunlop Direzza DZ101, 195/55&205/55 http://www.tirerack.com/tires/tires.jsp?ti...2&tab=Sizes http://www.tirerack.com/tires/tires.jsp?ti...romCompare1=yes |
Spoke |
Dec 10 2013, 10:59 AM
The 195/55/15 should work ok on the 7x15 wheels but not the 8x15.
The 195 is only 7.7 inches wide (195mm/25.4mm-per-inch). The 205 is 8.07 inches wide. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:40 PM |
