FS: My lifelong project garage sale, TONS of cool stuff, clean chassis |
Aaron Cox |
Dec 10 2013, 12:20 PM
All,
It Pains me to do this, but the realization has set in - I wont be able to ever finish this car until a lot later in life. I've owned this car since I was 15, and sadly its been taken apart and parked for the last 4 years. I'm through one grad program and about to start another. I plan to have kids soon... stuff like that. Not wanting to take a bath, but I've got lots of cool stuff in this lot for sale. Looking for one buyer if possible. More pics in my blog... http://www.914world.com/bbs2/index.php?aut...blogid=164& (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386699883.1.jpg) In her former glory.... current status (IMG:style_emoticons/default/sad.gif). Storage. (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-e-a.akamaihd.net-219-1386699971.1.jpg) She drove into the garage 3 years ago when I bought the condo... hasnt been driven since, just worked on here and there (IMG:style_emoticons/default/sad.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386701402.1.jpg) Suspension: FRONT 71 911 front end 3" struts. Ears milled and drilled for Boxster Brakes under 15" wheels. Work awesome. Poly bushings (spiral grooved) 930 - turbo tie rod ends Weltmeister bump steet kit replaced ball joints (now a few years old) replaced wheel bearings (now a few years old) Sway Away 22mm Torsion bars (i believe they are hollow) Koni Red inserts (914 specific not 911) Tarret Adjustable swaybar and droplinks Dlee suspension brace / tow bar setup REAR PMB control arms with poly bushings Currently apart to press in 911 hubs and boxster brake swap. (life long projects you see) 911 hubs (real 5 lug (IMG:style_emoticons/default/smile.gif) from 1971 911 Coleman racing threaded spring collars AFCO 225lb coils Bilstein sport shock absorbers Factory rear sway bar (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386700118.1.jpg) Brakes Boxster brakes front and rear (includes a 5th spare caliper) Milled front struts to accept adapters Bolt on rear adapters (Rich Johnson kit IIRC) 911 carerra rotors (front) (new a few years ago from PMB) 911 vented rear rotors from 71 911 911 e-brake setups (yet to be finished) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386701196.1.jpg) Engine GA case 2.0 crank 2L heads with fresh spark plug inserts Euro 94 pistons. Milled heads by R+D Machine (John Edwards) 9.x:1 CR (trying to remember) Weber 44 IDF's (italian) 34 venturi's IIRC (Tons of spare weber tuning parts in boxes as well, jets, floats, etc) CB performance carb linkage Mallory unilite distrubutor Mallory Hyfire 6A CDI ignition Mallory Promaster CDI coil 1.7 rockers 911 swivel feet valve adjusters CroMo pushrods Aurora 8mm plug wires VDO dual pressure sender VDO factory temp gauge sender and taco plate Have weltmeister tuna can (new and uninstalled) Have VDO CHT gauge, harness, sender (uninstalled) as well 38mm hi flow oil pump Full flow oil routing. Remote filter mount Thermostat and -10AN braided SS lines to front of car SETRAB front oil cooler Eurorace 4-1 header Eurorace muffler custom 911 muffler with sport exhaust look Eurorace Megaphone exhaust http://www.914world.com/bbs2/index.php?aut...ach&id=4149 Transmission RENNSHIFTER! 2 trannies! 1 factory side shifter that is original to the car. Worked great, leaked some oil. Probably needs a 1/2 synchro. [b]Short geared awesome newish tranny![/b] Sideshifter Rebuilt by THOMAS. (dogs/synchros/gaskets etc) Stock 1 / 2 ratios 3rd is flipped 5th gear 4th is 911 S gear 5th stock. Lots of new parts in this beast. Most synchros and dogs were replaced. Not many miles on this trans. driveline 915/923 (Rare and magical) 901 transmission compatible output flanges. 6 bolt, larger diameter - works with 944 CV's 944 CV joints 914 axles machined to accept the 944 CV's 944 Stub axles spacer to allow 944 stubs to connect to 71 911 hubs (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386700386.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386700749.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386701196.2.jpg) Wheels 15x7 and 15x8 factory 911 fuchs Polished/painted by Al Reed a few years ago Yokohama EVS100 225/50/15 and 205/50/15 tires 15x6 Fuch with spacesaver tire mounted - bolted to firewall 15x7 and 15x8 BBS rims powdercoated matte black. Never had tires mounted yet Spare 15x 7 gold BBS wheels as well. (2) Have Yoko A032R's unmounted for these too. Chassis 74 factory 2L car. Orginally zambezi green (l64k) 2 black paint jobs since (one PO..one under me) Metal rear fenders from Dan Callicots 914-6 race car (XITSPD - RIP bud) welded in. Allowing 8" fuchs to fit under stock looking fenders. Stainless steel fuel line in center tunnel. All new bushings throughout Clean euro tail lights No hell hole rust. Has had a battery tray welded in. Has a batter tray panel patch that could be done better. Rear trunk could use a new rear pan... (some rust holes) Hella H4's Hella rally lights on DLEE brackets Camp 914 pilot fog lights Front oil cooler installed. Louvered floor panel installed. New PPG windshield installed before parked... Interior Reupholstered dashcap with ashtray delete 904 combo gauge 912 tachometer silver center 150 speedo Spunone aluminum trim rings on all gauges (also have 10+ gauges in boxes... 914-6 combo gauges, tachs, speedos, 911 stuff) SCHEEL 914 specific deep bucket/race seats (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386700681.1.jpg) 5 point harnesses I believe i have rebuilt factory belts somewhere as well. Other cool stuff Uninstalled McMark GT roll hoop w/ door bars (like eric shea has) (IMG:http://www.914world.com/bbs2/uploads_offsite/scontent-b.xx.fbcdn.net-219-1386700518.1.jpg) Uninstalled AA metal fender flares 2 gas tanks (one from -6) 50's VW filler neck (same as 914 GT car) new cap (needs cool handle added) Chrome rear bumper Black painted front and rear bumpers GT Engine lid Spunone velocity stacks for weber IDF carbs. Engman passenger and drive Aluminum 'holed' floorboards (uninstalled) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-219-1386700317.1.jpg) VW super beetle towbar (mounts to front DLEE towbar mounts) All kinds of crazy things i have forgotten about. Will add a million pictures if people are interested. LOOKING FOR A LUMP SUM BUYOUT. Bring a truck, and trailer. And fill it to the brim with my 'life savings' worth of 914 coolness. Check my 'blog' here for more stuff i have forgotten. |
vinniedatorch |
Dec 10 2013, 03:28 PM
Newbie Group: Members Posts: 40 Joined: 12-January 13 From: Lakewood Ca. Member No.: 15,358 Region Association: Southern California |
Mark Henry |
Dec 10 2013, 03:34 PM
(IMG:style_emoticons/default/WTF.gif)
It sucks just reading this... dUdE.... (IMG:style_emoticons/default/sad.gif) |
KaptKaos |
Dec 10 2013, 03:35 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
NOOOOOOOOooooooo!!!!!!!!!!! (IMG:style_emoticons/default/headbang.gif)
Aaron Cox |
Dec 10 2013, 04:54 PM
Yorba Linda 92887
Price: gotta get all the boxes open and inventory everything. Just a million projects and an otherwise solid car. I know i'll never get what I have in it... Thinking its time to pack up and move on....(and come back another day when I have time/money to build one right) |
Dec 10 2013, 06:33 PM
Put a price on it.
Drums66 |
Dec 10 2013, 07:22 PM
(IMG:style_emoticons/default/WTF.gif) It sucks just reading this... dUdE.... (IMG:style_emoticons/default/sad.gif) ...... (IMG:style_emoticons/default/laugh.gif) (Aaron,your life just started) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/bye1.gif) |
hot_shoe914 |
Dec 10 2013, 09:35 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Rules say a price is required. (IMG:style_emoticons/default/poke.gif)
scotty b |
Dec 10 2013, 09:58 PM
Quitter (IMG:style_emoticons/default/dry.gif)
type47fan |
Dec 11 2013, 02:51 AM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Hoppie944s2 |
Dec 11 2013, 10:38 AM
Porschenut Group: Members Posts: 64 Joined: 7-July 13 From: New Jersey Member No.: 16,098 Region Association: North East States |
How much for the GT engine lid and filler neck?
etcmss |
Dec 11 2013, 11:46 AM
etcmss Group: Members Posts: 183 Joined: 20-April 06 From: Lancaster, Ky Member No.: 5,899 Region Association: Upper MidWest |
price for the whole car (all parts, etc).
not an open bidding war on each item---if that is what the post is about (to sell all the parts) then move it to parts. Gary |
billh1963 |
Dec 11 2013, 02:08 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I'll start the bidding...$1! (IMG:style_emoticons/default/biggrin.gif)
Highland |
Dec 11 2013, 05:22 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
How much for the stock side-shift transmission?
sixnotfour |
Dec 11 2013, 05:40 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
It wouldn't be a complete Aaron post without the bare foot picture in it.......
Yes there is one...Good Luck, Happy Life.. |
bulitt |
Dec 13 2013, 05:49 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Wow, there are some nice parts here! Lost track of how many cars I have sold for my family, college tuition etc. Would do it all again in a heartbeat.
(IMG:style_emoticons/default/icon_bump.gif) |
euro911 |
Dec 18 2013, 12:04 PM
C'mon Aaron, throw a BBQ this summer and let's get it back together |
eric9144 |
Dec 18 2013, 12:28 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
(IMG:style_emoticons/default/dry.gif) C'mon Aaron, throw a BBQ this summer and let's get it back together (IMG:style_emoticons/default/agree.gif) |
ndfrigi |
Dec 18 2013, 01:26 PM
Aaron, I'm in to help also!
chadhuskey |
Dec 18 2013, 09:08 PM
Newbie Group: Members Posts: 1 Joined: 5-December 10 From: columbus Member No.: 12,453 Region Association: None |
price?
Lo-Fi Version | Time is now: 16th May 2024 - 10:27 PM |
