My new 2.0 won't start, Need help!! |
kkid |
Dec 13 2013, 04:30 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
Hi guys,
I spent last few weeks to prep on my newly acquired 2.0 and it's finally in the car! But she doesn't wanna wake up.... (IMG:style_emoticons/default/sad.gif) I know our Bay has been cold lately...but today is beautiful!!! It turns over, has fuel pressure around 30psi when cranking(20psi soon after when the key turned off), static timing done after points gap adjusted, all the electrical connections checked I think, and what else??? Actually there're at least 2 concerns I can think of. When I got the motor, the dizzy rotor was pointing somewhere around#4 position when the TDC mark was showing in the round window. So I moved the gear in order for rotor to point #1 as I confirmed the valves were loose. But wondering if I did it correctly. I took the gas tank out as I installed stainless fuel lines. The tank was sitting in my garage for about a week or so then it developed some rust. So I cleaned inside with rust remover. But I might not have rinsed it well enough. New fuel filter still looks clean after uncountable numbers of attempt of starting the motor. New fuel sock is in the tank. So I am stuck now (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) What do you all think I screwed? Thanks in advance, kkid (IMG:style_emoticons/default/smile.gif) |
krazykonrad |
Dec 13 2013, 04:37 PM
Senior Member Group: Members Posts: 1,126 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Are you starting the engine with it in the car o on an engine stand?
Konrad |
Rand |
Dec 13 2013, 04:38 PM
I didn't hear you say you had a good spark at the plugs. Seems too obvious, but.... Do you?
kkid |
Dec 13 2013, 04:45 PM
kkid |
Dec 13 2013, 04:47 PM
kkid |
Dec 13 2013, 04:48 PM
sorry, I gotta p/u my daughter from school.
Kirmizi |
Dec 13 2013, 05:11 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
I didn't hear you say you had a good spark at the plugs. Seems too obvious, but.... Do you? (IMG:style_emoticons/default/agree.gif) It takes a combination of fuel + air + spark to fire. Start by checking the basics |
gunny |
Dec 13 2013, 05:19 PM
Member Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States |
If you have a dwell meter hook it up and measure the dwell while turning it over. Should be 45-47.
You said that the fuel presure drops after cranking, does it go to about 0 shortly after you turn the key off? |
type47 |
Dec 13 2013, 05:22 PM
I'm putting my money on the distributor drive gear is misaligned/improperly located. If the timing is close and you have fuel and spark, it should at least cough...
TheCabinetmaker |
Dec 13 2013, 06:19 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Fuel lines at fuel rails are crossed?
euro911 |
Dec 13 2013, 06:26 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
... When I got the motor, the dizzy rotor was pointing somewhere around#4 position when the TDC mark was showing in the round window. So I moved the gear in order for rotor to point #1 as I confirmed the valves were loose. But wondering if I did it correctly. You'll see the TDC marker in the window for every revolution of the crank, not just for cylinder #1. Make absolutely sure you're at TDC on cyl # 1. The fact that you said it was pointing at cyl # 4 and you had to rotate go the dizzy drive gear 180° has me wondering if you were watching TDC for cyl # 4 instead of # 1 (IMG:style_emoticons/default/confused24.gif)kkid (IMG:style_emoticons/default/smile.gif) For a spark check, pull one of your spark plugs out and lay it where you can see it. Keep the hi tension lead attached and ground the threaded portion with a good-sized alligator clip and jumper cable, then have an assistant crank the motor while you watch for spark. |
Rand |
Dec 13 2013, 06:46 PM
I didn't hear you say you had a good spark at the plugs. Seems too obvious, but.... Do you? how can you tell if it's good or weak spark? One easy trick is to just pull a plug wire, plug in a good new spark plug, hold the threads of said plug to the block....Or some good ground.... And have someone crank the starter while you watch the spark. That bugger should scare you with a nice fat blue/white spark. If it is weak and yellow then we have a troubleshooting track to go down. |
914sgofast2 |
Dec 13 2013, 07:09 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
By changing the distributor drive gear around whn you got the motor back from the engine builder, you probaly have it 180 degrees out of time. The is only one correct position for the cam, crank and distributor to all be timed correctly when the engine is assembled. Let's assume the engine builder did it right, but the engine was turned over by hand after it was assembled, probably when they installed the fan & alterntor belt.
The firing order is 1-3-4-2. That means whenever TDC comes up to the timing mark/pointer, the rotor will either be pointing to #1 or #4 cylinder (and no others). Switch the distributor drive gear back to where it was when you got he engine and then set the static timing of the distributor. I bet it will probably start right up. I once had a similar problem with a 1960 Alfa Romeo Gielietta. The PO's previous mechanic had installed the distributor shaft drive gear wrong by 180 degress and then moved all the plug wires on the cap by 180 degress to make it run, instead of tearing the engine down to install the distributor shaft drive gear correctly. There is a reason the distributor shaft drive has a gear at one end and an offset "notch" at the other. |
wndsnd |
Dec 13 2013, 07:27 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
By changing the distributor drive gear around whn you got the motor back from the engine builder, you probaly have it 180 degrees out of time. The is only one correct position for the cam, crank and distributor to all be timed correctly when the engine is assembled. Let's assume the engine builder did it right, but the engine was turned over by hand after it was assembled, probably when they installed the fan & alterntor belt. The firing order is 1-3-4-2. That means whenever TDC comes up to the timing mark/pointer, the rotor will either be pointing to #1 or #4 cylinder (and no others). Switch the distributor drive gear back to where it was when you got he engine and then set the static timing of the distributor. I bet it will probably start right up. I once had a similar problem with a 1960 Alfa Romeo Gielietta. The PO's previous mechanic had installed the distributor shaft drive gear wrong by 180 degress and then moved all the plug wires on the cap by 180 degress to make it run, instead of tearing the engine down to install the distributor shaft drive gear correctly. There is a reason the distributor shaft drive has a gear at one end and an offset "notch" at the other. 1-4-3-2. (IMG:style_emoticons/default/santa_smiley.gif) |
jdlmodelt |
Dec 13 2013, 07:35 PM
James D. Lane Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region |
I thought these distributors had a slot that only permits you to install the distributor drive in the right possition, in which case you have to change the timing by rotating the spark plug wires by 180 degrees clockwise or counter clockwise, either way ends up in the same place.
Also, check for spark while you are at it. |
Jeffs9146 |
Dec 13 2013, 08:23 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Lennies914 and I had the same problem, it turned out to be the injection trigger points in the dizzy were sticking! We opened up the dizzy, replaced the trigger plate and it started right up!
Tom |
Dec 13 2013, 08:28 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
If you changed the distributer 180 degrees, change the spark plug wires accordingly.
Tom |
kkid |
Dec 14 2013, 12:01 AM
If you have a dwell meter hook it up and measure the dwell while turning it over. Should be 45-47. You said that the fuel presure drops after cranking, does it go to about 0 shortly after you turn the key off? I haven't set the dwell but point gap. Fuel pressure drops down to 20psi and it holds there for a long time. I still see 10psi next morning. |
kkid |
Dec 14 2013, 12:04 AM
kkid |
Dec 14 2013, 12:09 AM
Lo-Fi Version | Time is now: 22nd May 2024 - 03:17 AM |
