rear hub drilling four to five, machining advice needed |
pete-stevers |
Dec 29 2004, 10:58 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
I am taking the rear hubs to a machinist to drill and insert studs into my bros hubs...I want to do it right...any threads on this topic with pics...What type of studs to use..any re-enforcement nessary... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
thanks steve |
Demick |
Dec 29 2004, 11:15 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Use standard length 911 studs (56mm pops in my mind but I'm not sure if that is correct). Take the studs to the machinist before he starts. If he is any good, he will know what size holes to drill based on the studs. All you should need to tell him is drill on 5x130mm. One of the original threaded holes will be re-used for the new pattern. He should use a rotary table, and do it all from the back side since each hole will need to be spot faced from the back as well.
If the machinist asks too many questions - run away. Easy job for any competent machinist with the right tools. s |
pete-stevers |
Dec 29 2004, 11:22 PM
cheers (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
I have a set of five bolt hubs but I think my poor brother is saving for a ring (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) ... so we are doing it on a budget... thanks steve (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
dcicchetto914 |
Dec 31 2004, 05:31 PM
Member Group: Members Posts: 74 Joined: 6-December 04 From: San Diego, CA Member No.: 3,230 |
I wanna get the same done, anyone know how much it costs. Can I set up a jig and do it myself or will I cause a car accident...
Thanks, Drue |
Lo-Fi Version | Time is now: 16th May 2024 - 05:11 PM |
