914 2.0 Master Cylinder Choice, Should I choose the German OEM ATE or go with the cheaper URO |
LevisJeanz |
Dec 16 2013, 12:55 PM
Newbie Group: Members Posts: 7 Joined: 3-March 12 From: Seattle, WA Member No.: 14,210 Region Association: Pacific Northwest |
I have a 1975 914 2.0 that I converted to carbs. The brake master cylinder dumps about 1-2 tablespoons of fluid when the brake pedal is pressed. I obviously need a new MC. I want to upgrade to the 19 mm MC and there are two options. I could spend $260+ and buy the porche OEM equivalent by ATE or spend $60 - $90 on a cheaper variant from URO. I don't know if I want to skimp out on the braking system because it could save my life and all.
What are your recommendations? Has anyone been using the URO equivalent? Thanks, -Levi- |
GeorgeRud |
Dec 16 2013, 01:02 PM
It seems the URO ones may have issues with quality control. As the master cylinder should last you for years, I'd spend the extra and get the ATE one.
smveril |
Dec 16 2013, 01:15 PM
Mikey Group: Members Posts: 50 Joined: 6-December 04 From: Cincinnati, OH Member No.: 3,232 Region Association: Upper MidWest |
I put an OEM master cylinder in my 73 over 20 years ago and it still works fine so I would vote for the best quality part.
JFJ914 |
Dec 16 2013, 01:25 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
ATE !
flipb |
Dec 16 2013, 01:34 PM
Senior Member Group: Members Posts: 1,722 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
The PO of my 914 put in a 19mm MC... I don't know the manufacturer, but it failed within 3 years (at which point I owned the car).
76-914 |
Dec 16 2013, 02:21 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
This is "the" area where you spend "TOP" dollar, not bottom dollar.
billh1963 |
Dec 16 2013, 03:33 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
This is "the" area where you spend "TOP" dollar, not bottom dollar. (IMG:style_emoticons/default/agree.gif) Never skimp on tires or brakes |
dlee6204 |
Dec 16 2013, 06:28 PM
I've used the URO MC for years without issue. I don't think I've ever heard of a failure first-hand, just rumors.
JamesM |
Dec 16 2013, 06:34 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Say you were being forced to jump out of an airplane but you have your choice of parachutes.
#1 is used by say, some special forces team #2 is made in china using questionable methods and unknown materials. Sure they both might do the job but... its your life, you pick |
boxsterfan |
Dec 16 2013, 06:36 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
What are the different part#'s between the URO and ATE makers of the 19mm Master Cylinder?
gothspeed |
Dec 16 2013, 09:29 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Spending more money doesn't automatically get you the best of anything. I have seen plenty of expensive parts fail, no part is immune from that. Even 'name brand' components or sub-components (seals etc.), are being made in third world countries these days. Do your homework and inspect the parts before you put them on, no matter how much you paid for it.
VaccaRabite |
Dec 17 2013, 01:24 PM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I've used the URO MC for years without issue. I don't think I've ever heard of a failure first-hand, just rumors. I bought one. It failed in the first few months, before the car ever even got road time (lucky). Replaced it with an ATE. The Uro ended up being a really REALLY expensive MC.... Now they are not just rumors for you. Zach |
gothspeed |
Dec 17 2013, 02:14 PM
I've had an ATE MC fail within a few months ..... there was a defect in the casting that began leaking after seeing pressure ........ (IMG:style_emoticons/default/headbang.gif)
76-914 |
Dec 17 2013, 06:28 PM
Spending more money doesn't automatically get you the best of anything. I have seen plenty of expensive parts fail, no part is immune from that. Even 'name brand' components or sub-components (seals etc.), are being made in third world countries these days. Do your homework and inspect the parts before you put them on, no matter how much you paid for it. Nope, but $5 will get you $10, that's where the "smart" money goes when shopping brakes. I take short cuts on this Frankenstein that I'm building that I would never take when building an airplane. Do you see the common thread here? Our butt's. (IMG:style_emoticons/default/lol-2.gif) |
gothspeed |
Dec 17 2013, 06:55 PM
Nope, but $5 will get you $10, that's where the "smart" money goes when shopping brakes. I take short cuts on this Frankenstein that I'm building that I would never take when building an airplane. Do you see the common thread here? Our butt's. (IMG:style_emoticons/default/lol-2.gif) ........................ (IMG:style_emoticons/default/yellowsleep[1].gif) |
LevisJeanz |
Dec 20 2013, 02:39 AM
Thanks for the advice guys I just picked up the ATE 19mm MC from my local shop ~$285 after taxes.
Lo-Fi Version | Time is now: 22nd May 2024 - 02:41 AM |
