2 Pages V < 1 2
> price check, i'm clueless
Old Yella
post Dec 21 2013, 03:07 PM
Post #21
Old Yella
They look like 1970-71 E to me, God, could I use them.
Do they have 5 or 6 in the triangle above the skirt.
Do they have 5 or 6 stamped in the triangle?
See attached web site for comparison of pistons/ No affiliation to this site.
http://www.bassant-parts.com/contents/en-uk/d4913_01.html
Old Yella
post Dec 21 2013, 03:13 PM
Post #22
Old Yella
They are listed as
911 S 175 hp
€ 2'400.00 911 103 949 02
Bummer I couldn't use them
http://www.elevenparts.com/mahle.php
Old Yella
post Dec 21 2013, 03:15 PM
Post #23
Old Yella
$3281.52 dollars
wndsnd
post Dec 21 2013, 03:57 PM
Post #24
You wanted a horse, but got a goat. Nobody wants a goat....
I was right !
euro911
post Dec 21 2013, 04:11 PM
Post #25
QUOTE(euro911 @ Dec 20 2013, 01:47 PM) *
I parted out a 2.2 long block for about $3,800 ... 30 years ago
I kept the heat exchangers cuz they were better than my originals
Guess I should have kept it around for a while (IMG:style_emoticons/default/headbang.gif)
I shouldn't complain, I bought the engine for $150. and sold my old set old set of HEs for that much. Come to think of it, I think I still have some populated 2.2 heads in a box around here (IMG:style_emoticons/default/confused24.gif) ... I'll have to look (IMG:style_emoticons/default/idea.gif)
rudedude
post Dec 21 2013, 04:19 PM
Post #26
Sure looks like a cast iron cylinder that was used on 84mm "T"s, E and S used biral cylinders(aluminum finned cast iron sleeves)
jcd914
post Dec 21 2013, 04:30 PM
Post #27
QUOTE(Old Yella @ Dec 21 2013, 01:13 PM) *
They are listed as
911 S 175 hp
Except the part number on the box is 911 103 942 02 not 911 103 949 02
The 942s looks like might be 72/73 2.4 p & Cs
Jim
Old Yella
post Dec 21 2013, 04:45 PM
Post #28
Old Yella
SORRY, must put my glasses on.
But look at the piston top they don't look like T pistons the pocket appears to be too big. Or may be It just looks that way without GLASSES.
Old Yella
post Dec 21 2013, 05:13 PM
Post #29
Old Yella
I should have looked on the box. With glasses.
Last digit is wrong, mahl number listed as follows
503 18 90 Mahle PISTON & CYLINDER
Porsche 911 1972, 1973 MAHLE - CR 7.5:1 - EXC. CIS
Porsche 911 1972, 1973 2.3L H6 911.51 MAHLE - CR 7.5:1 - EXC. CIS
Old Yella
post Dec 21 2013, 05:27 PM
Post #30
Old Yella
I'm still not sure.
Look at the piston comparison c/o Tom1394racing on the pelican site.
pistons don't look like T to me, But then I'm half blind so who knows.
Luke M
post Dec 21 2013, 10:15 PM
Post #31
QUOTE(euro911 @ Dec 21 2013, 12:28 PM) *
QUOTE(Luke M @ Dec 21 2013, 07:28 AM) *
QUOTE(rhodyguy @ Dec 20 2013, 02:07 PM) *
box #
2.2 and 2.4 engines have the same bore but different compression ratios.
I know some people and I have swapped out the 2.4 pistons for the 2.2 pistons to give yourself a few more hp. I looked up the part # on the box that you have. The closest thing that I found with the part # was used as a 2.4 T p/c set (non cis).
If you look inside the piston you will see some letters/numbers this will confirm what you have. Look at the list attached to see what you have. Your best bet would be to figure out what you have then list them on the Pelican site. I've had better luck selling 911 p/c's there.
The stroke is different - 66 for the 2.2 vs 70 for the 2.4.
Yup, I knew that the stoke was different (66 vs 70.4) that's why I said that the bore is the same between 2.2 &2.4 other then compression ratio. Put the 2.2 pistons in a 2.4 engine and you get a few more hp. Good upgrade for someone that's rebuilding a 2.4 and wants a little more out of it.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 30th August 2025 - 01:44 PM
