FS: Parting out D Prepared project car, Go-fast pieces inside====> |
BMXerror |
Dec 21 2013, 04:18 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Well, here goes. Parting out an unfinished project to run in the D Prepared class of SCCA autocross. Still taking pieces off, but here's what I have so far. Please PM me for any interest as I may not get around to checking this thread as often as I should.
-Complete oil Cooler setup- Mesa 96 plate oil cooler with fan (Ugly chrome paint came on the fan. Not my idea), 170 degree oil cooler thermo-bypass, and thermostatic fan switch, all from Moore Parts. Also included is a stock T4 oil cooler block-off plate from CIP1, and a home modified engine sheet metal piece that blocks off the airflow to the stock cooler. The brackets have been cut and modified for my installation. Unmolested brackets can be found here: http://www2.cip1.com/ProductDetails.asp?Pr...ode=C26-117-120 Hoses not included because they were ready to be replaced. Three hundred thirty dollars in parts if you include all the brass barbed fittings that don't come with the kits. I'll let go for $200. -Core 1.7 long block- Bottom end is very solid. High flow oil pump. FAT 440mp camshaft with strait cut cam gears. Pelican Parts deep sump kit installed. Low mile AA pistons and cylinders. 1.7 heads are in rough shape. Some cracks around exhaust studs. I would replace these. $350 Local pickup only. -Cutch pieces- Kennedy Stage 1 pressure plate and stock disc. Both with less than 10k miles on them. Pressure plate bolts weren't in the best shape, so I won't include them with the kit. Plenty of meat left on the disc. $160+ shipping for both pieces. -Complete stock side shift linkage including middle and rear coupler bushings. Will throw in a side shift engine mount too if needed. $100. Local pickup preferred. -Other misc parts: Pictures: Oil cooler kit Engine Clutch Shift linkage That's it for now. Other parts to come include window glass, windshield, and two core transmissions. Thanks for looking. Updates to follow. Mark D. |
Lo-Fi Version | Time is now: 28th May 2024 - 08:14 AM |
