How do you make fog lights independent of low beam?, I want to use my fog lights when high beam is on! |
R8CERX |
Dec 26 2013, 06:06 AM
2014 New year resolution: To get along with Woody... Group: Members Posts: 606 Joined: 5-June 13 From: California Member No.: 15,972 Region Association: Southern California |
I know the rationale and background to not have the fog lights come on when high beams are turned on- you ain't supposed to use high beams during fog
But i am interested in: 1- be able to turn on my fog lights without my main pop up lights come up 2-be able to turn my fog lights with high beam on 3-adding an extra pair of off road lights with a possible independent switch End result I am interested: Low and high beams remain same with the pop up lights My fog lights can be turned on independently of the main pop up lights; don't want to have the pop up lights come up if they are not on Have a third set or a new pair of off-road lights via a dedicated switch Want to do the above so I still keep originality of car and still be able to put car back with minimum work Suggestions? Electric Diagrams? Anyone done this before? Pictures? Opinions, ideas, comments, suggestions, help and any other well intentioned and positive feedback appreciated (IMG:style_emoticons/default/confused24.gif) |
02loftsmoor |
Dec 26 2013, 06:22 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
There are a couple of kits you can use. Automation?.
type47 |
Dec 26 2013, 06:23 AM
here is a start (I didn't read the whole thing but seemed to be a start for you)
http://members.rennlist.com/demick/fogrewire.html |
tomeric914 |
Dec 26 2013, 07:38 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
I use mine as DRLs. The switch turns them on regardless of headlight operation as long as the ignition switch is on. It's a matter of determining which relay controls the fog lights, snipping or unplugging the wire that IIRC comes right off the fuse box and connecting it to an ignition powered source on the fuse box.
JawjaPorsche |
Dec 26 2013, 08:36 AM
cary |
Dec 26 2013, 09:31 AM
Ditto, I have one laying in the tray of winter projects. Looks pretty simple. |
Cap'n Krusty |
Dec 26 2013, 09:50 AM
Fog lights are functionally useless when used with the high beams, and high beams are useless, if not downright dangerous, in foggy conditions. DOT regulations mandate a link to low beams for the fog lights. Oncoming drivers will curse you as you approach with both high beams and fogs illuminated. Properly conducted scientific studies have conclusively PROVEN that using your fog lights as auxiliary/supplemental lighting in conjunction with high beams actually REDUCES the driver's ability to see objects at a distance, something that is VERY important as speed increases. Your eyes are desensitized by the relatively bright light in the foreground, making poorly lit objects at greater distances difficult, if not impossible, to see. Wiring the fogs to work as anything other than low beams is not only illegal, it's dumb. Make that "stupid". Right up there with folks who take flash pictures from the stands at night sporting events. BTW, using driving lights mounted in the bumper is also a waste of time, as the location and angles are all wrong for the purpose.
The Cap'n, got his Krusty refueled yesterday! Thanks, Santa! Edit: You are allowed TWO pairs of forward facing lights (4 bulb headlight systems count as one pair). If you have main bulbs, fogs, and driving lights, you MUST keep one of those pairs covered. That's why you see the offroaders (and offroad poseurs) with covers or bags on some of the lights when driving on public roads. I'll add a picture in my next post. |
Cap'n Krusty |
Dec 26 2013, 10:04 AM
Poorly positioned, but legally covered, examples of auxiliary lighting as demonstrated on poseurmobiles. The Cap'n |
ripper911 |
Dec 26 2013, 10:13 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I like the idea of being able to flash other drivers without having to pop up the headlights, that's about the best use for this idea as far as I can tell.
JeffBowlsby |
Dec 26 2013, 10:50 AM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Fog lights are functionally useless when used with the high beams, and high beams are useless, if not downright dangerous, in foggy conditions. DOT regulations mandate a link to low beams for the fog lights. Oncoming drivers will curse you as you approach with both high beams and fogs illuminated. Properly conducted scientific studies have conclusively PROVEN that using your fog lights as auxiliary/supplemental lighting in conjunction with high beams actually REDUCES the driver's ability to see objects at a distance, something that is VERY important as speed increases. Your eyes are desensitized by the relatively bright light in the foreground, making poorly lit objects at greater distances difficult, if not impossible, to see. Wiring the fogs to work as anything other than low beams is not only illegal, it's dumb. Make that "stupid". Right up there with folks who take flash pictures from the stands at night sporting events. BTW, using driving lights mounted in the bumper is also a waste of time, as the location and angles are all wrong for the purpose. The Cap'n, got his Krusty refueled yesterday! Thanks, Santa! Edit: You are allowed TWO pairs of forward facing lights (4 bulb headlight systems count as one pair). If you have main bulbs, fogs, and driving lights, you MUST keep one of those pairs covered. That's why you see the offroaders (and offroad poseurs) with covers or bags on some of the lights when driving on public roads. I'll add a picture in my next post. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Drivers using all those lights, and lights improperly aimed (should be aimed at the ground surface), are a nuisance to approaching drivers (blinding them) and creating a safety hazard. Don't do it. |
Kaduku |
Dec 26 2013, 10:56 AM
Member Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
I got the JWest module too. Love it, I now always drive with the fog lights on during the day.
Dec 26 2013, 11:04 AM
If you do this, there is a high likelihood that your car may blow up and you may end up in hell.
Re wiring lights or replacing lightbulbs with overly powerful off-road only lights that blind other drivers is constantly checked by the authorities in roadside spot checks each and every time a customer complaint if filed, or each time they see lights that are aimed at the oncoming traffic. (IMG:style_emoticons/default/smile.gif) |
type47 |
Dec 26 2013, 11:06 AM
? answered in above post
palmer_md |
Member Group: Members Posts: 106 Joined: 15-November 10 From: Hermosa Beach, CA Member No.: 12,389 Region Association: Northern California |
Poorly positioned, but legally covered, examples of auxiliary lighting as demonstrated on poseurmobiles. The Cap'n Another nice example if you press "home" in the upper right corner of this website. At least it is there for the next few days, not sure when it is going to change. |
R8CERX |
Dec 26 2013, 12:40 PM
Oh my.... Oh my.....
This is what I love about our brotherhood....... The great experience, the well meaning responses, and the expected motherly taps on the head one gets when trying to understand a topic..... (IMG:style_emoticons/default/chair.gif) I got to be honest, these nice motherly taps are really why I live for to wake up every morning and keep me glued to this humble and expensive website.... The $19.99 I sent every month to cap'n krusty is worth the smiles I get when I sit in my warm California toilet catching up to the daily updates.... (IMG:style_emoticons/default/av-943.gif) I am now considering putting the lights on my rear bumper for those tailgaters.... Since I already carry my AK-47 on my gun rack just behind my 914-6 seat... (IMG:style_emoticons/default/screwy.gif) I do realize the logic and concerns about the angle and strength of the ligths and the nuisance it may imposed on our fellow on coming traffic human beings, but I have seen quite many of our great members with their beautiful teners and I like the looks of the external off-road lights and the ability to also not have my main lights pop up during day driving so I can reduce my drag coefficient and perhaps gain my 0.00076534 in horse power.... (IMG:style_emoticons/default/blink.gif) Thank you for the vivid advise, links and suggestions..... Can't wait to be in traffic awaiting the cap'n and fellow conspirators...... (IMG:style_emoticons/default/poke.gif) Note: All fun aside- thank you for real; I can now check out some ideas and options- I love 914world!! We should have some stickers to demonstrate our addiction...! (IMG:style_emoticons/default/aktion035.gif) |
R8CERX |
Dec 26 2013, 12:42 PM
I like the idea of being able to flash other drivers without having to pop up the headlights, that's about the best use for this idea as far as I can tell. (IMG:style_emoticons/default/piratenanner.gif) |
R8CERX |
Dec 26 2013, 12:45 PM
Great suggestion.... But just read in the fine print it specifically does not work on the 914-6.....rrrrrrrr (IMG:style_emoticons/default/hissyfit.gif) |
R8CERX |
Dec 26 2013, 12:47 PM
here is a start (I didn't read the whole thing but seemed to be a start for you) http://members.rennlist.com/demick/fogrewire.html It is a good start; not sure it works on the -6 |
Mark Henry |
Dec 26 2013, 01:19 PM
Fog lights are functionally useless when used with the high beams, and high beams are useless, if not downright dangerous, in foggy conditions. DOT regulations mandate a link to low beams for the fog lights. Oncoming drivers will curse you as you approach with both high beams and fogs illuminated. Properly conducted scientific studies have conclusively PROVEN that using your fog lights as auxiliary/supplemental lighting in conjunction with high beams actually REDUCES the driver's ability to see objects at a distance, something that is VERY important as speed increases. Your eyes are desensitized by the relatively bright light in the foreground, making poorly lit objects at greater distances difficult, if not impossible, to see. Wiring the fogs to work as anything other than low beams is not only illegal, it's dumb. Make that "stupid". Right up there with folks who take flash pictures from the stands at night sporting events. BTW, using driving lights mounted in the bumper is also a waste of time, as the location and angles are all wrong for the purpose. The Cap'n, got his Krusty refueled yesterday! Thanks, Santa! Edit: You are allowed TWO pairs of forward facing lights (4 bulb headlight systems count as one pair). If you have main bulbs, fogs, and driving lights, you MUST keep one of those pairs covered. That's why you see the offroaders (and offroad poseurs) with covers or bags on some of the lights when driving on public roads. I'll add a picture in my next post. But the hizzle to the shizzle still looks bling Krusty Daddy-O! (IMG:style_emoticons/default/elvira.gif) |
scott_in_nh |
Dec 26 2013, 01:38 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
I use mine as DRLs. The switch turns them on regardless of headlight operation as long as the ignition switch is on. It's a matter of determining which relay controls the fog lights, snipping or unplugging the wire that IIRC comes right off the fuse box and connecting it to an ignition powered source on the fuse box. I wired mine to come on independantly for use as DRLs AND they still turn off with the hi beams. No kit is required. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:35 PM |
