Running fuel and brake lines under the car..., mounting options? |
falcor75 |
Dec 26 2013, 07:58 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I'm in the middle of restoring my shell and I dont think I want to run the fuel and brake lines down the center tunnel again but instead run them under the car.
Anyone else done it and if so what kind of mountings did you use? |
Dec 26 2013, 08:19 AM
914-6 GT in waiting Group: Members Posts: 19,275 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I wouldn't. One higher than average speed bump would wreck everything. Stock location is the way to go. Chris Foley at tangerine racing makes ss fuel lines that fit perfectly and eric shea at pmb performance does the same for the brake lines.
(IMG:style_emoticons/default/welcome.png) |
reharvey |
Dec 26 2013, 08:28 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
[quote name='mepstein' date='Dec 26 2013, 09:19 AM' post='1975034']
I wouldn't. One higher than average speed bump would wreck everything. Stock location is the way to go. Chris Foley at tangerine racing makes ss fuel lines that fit perfectly and eric shea at pmb performance does the same for the brake lines. (IMG:style_emoticons/default/welcome.png) [/quote (IMG:style_emoticons/default/agree.gif) |
TheCabinetmaker |
Dec 26 2013, 09:04 AM
esposed fuel lines under the car? Can you say death trap?
rick 918-S |
Dec 26 2013, 09:14 AM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Please don't do that. American cars that run fuel and brake lines under the car attach them to the side of a stout frame rail or can locate them up high enough in a section of the unit body that they can be crushed or damaged.
rhodyguy |
very bad ideas. you'll spend 'more time' cobbling the lines in than doing it the right way.
falcor75 |
Dec 26 2013, 10:41 AM
I know that Chris at Tangerine makes nice stuff as I have his rear suspension kit going onto the car. Shipping fuel lines across the atlantic feels like a bad idea tho, shipping costs would be huge due to the length of the package.
I'll think on your comments tho I've never scraped the underside of any car on a speedbump.... |
JawjaPorsche |
Dec 26 2013, 10:49 AM
To me the cost of doing the job right would out weigh the cost of doing it wrong.
Mike Bellis |
Dec 26 2013, 11:13 AM
I'll think on your comments tho I've never scraped the underside of any car on a speedbump.... Famous last words... What will you do when the car is dragging a fire ball and you can't stop??? (IMG:style_emoticons/default/confused24.gif) I guess you can try to drive faster so the fire can't catch you... (IMG:style_emoticons/default/evilgrin.gif) |
Dec 26 2013, 04:12 PM
Buy some bulk stainless steel brake lines and make your own lines, but run them THROUGH the tunnel so your restoration is done properly and you won't regret doing it the right way the first time.
gothspeed |
Dec 26 2013, 05:51 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I bought some bulk SS fuel line from Jegs, formed them and ran them through the tunnel. While I did save a little money .... looking back at the amount of work it was to measure, bend, cut and flare the line ..... if I were to do this again .... I would get the pre-formed lines from tangerine ..... I think they are a good value ... (IMG:style_emoticons/default/smile.gif)
Dec 26 2013, 10:03 PM
I bought some bulk SS fuel line from Jegs, formed them and ran them through the tunnel. While I did save a little money .... looking back at the amount of work it was to measure, bend, cut and flare the line ..... if I were to do this again .... I would get the pre-formed lines from tangerine ..... I think they are a good value ... (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) Took me 5 minutes to run through the tunnel with my son helping me as a spotter. |
worn |
Dec 26 2013, 10:19 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I bought some bulk SS fuel line from Jegs, formed them and ran them through the tunnel. While I did save a little money .... looking back at the amount of work it was to measure, bend, cut and flare the line ..... if I were to do this again .... I would get the pre-formed lines from tangerine ..... I think they are a good value ... (IMG:style_emoticons/default/smile.gif) I bought he bulk tubing as well. Very inexpensive and compatble with an anodized bling. Didnt takeany work at all to thread through the tunnel. Brakes would be easier. |
carr914 |
Dec 27 2013, 01:54 AM
Racer from Birth Group: Members Posts: 118,695 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
OP, this is the Worst Idea I have ever heard - Don't do it.
Do it right, your family will Thank you without even knowing it, just by still having you around |
ChrisFoley |
Dec 27 2013, 08:11 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Shipping fuel lines across the atlantic feels like a bad idea tho, shipping costs would be huge due to the length of the package. Actually its not as bad as you might think. Typical length limitation to European countries is 60 inches, and my package is only 58" long. There would be a substantial savings if one other person you know also bought a set at the same time. Earlier this year I shipped 4 sets, one with hoses, etc. to The Netherlands. Total shipping/handling cost was $80. I'm guessing one or two sets of stainless lines only would cost around $60. |
gothspeed |
Dec 27 2013, 01:50 PM
I bought he bulk tubing as well. Very inexpensive and compatble with an anodized bling. Didnt takeany work at all to thread through the tunnel. Brakes would be easier. (IMG:style_emoticons/default/agree.gif) Took me 5 minutes to run through the tunnel with my son helping me as a spotter. I still think the preformed and beaded lines from Chris are a good value ... (IMG:style_emoticons/default/beerchug.gif) |
wndsnd |
Dec 27 2013, 03:44 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
The beaded line kit from Tangerine is a fantastic product. I fed them through the tunnel by myself and they probably took 5 minutes tops. They were not much money for the piece of mind I have.
Also make sure you use the proper soft lines these days as well that will stand up the the methynol. Chris will set you up with that as well. John |
Dec 27 2013, 05:28 PM
ChrisFoley |
Dec 27 2013, 10:12 PM
Typical length limitation to European countries is 60 inches, and my package is only 58" long. I call BS on that statement. Order a set and I'll ship them to you so you can measure the box. (IMG:style_emoticons/default/bootyshake.gif) |
rhodyguy |
Dec 27 2013, 10:13 PM
ha. funny.
Lo-Fi Version | Time is now: 19th May 2024 - 09:54 AM |
