H.D. Oil Pump Drive, 1mm too long? |
Allan |
Dec 31 2004, 02:32 PM
I have a new H.D. oil pump I want to use. I am wanting to reassemble the cases today but I forgot about the 1mm maching that needs to be done on the drive tang to prevent it from preloading the cam. It this something that can be done using a bench grinder or do I need to wait until next week (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) and find a machine shop?
Allan |
Dec 31 2004, 03:01 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) Anybody? Kinda like to do this today if possible. I'll even post pics.
Dominic |
Dec 31 2004, 03:11 PM
Dominic Group: Members Posts: 991 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
I've done this on the bench grinder before, just make sure you don't take off too much, best to accurately measure it with a mic or a caliper. Don't let it get too hot when your grinding, dip it in some oil or water.
No big deal. |
Allan |
Dec 31 2004, 03:13 PM
Thanks. I'm goin in.....
dlee1967 |
Dec 31 2004, 03:14 PM
V8Lurker Group: Members Posts: 540 Joined: 20-February 03 From: Splendora, TX Member No.: 327 Region Association: None |
I used a file for better control so that I could get a square edge. No overheating issues either. DLee
Allan |
Dec 31 2004, 03:54 PM
Okay, I might have screwed the pooch. Anyone know what the minimum height the tang has to be. I'm looking at approximately .275 after grinding.
KenH |
Dec 31 2004, 04:14 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
I have put in 2 and had NO problem. Try and assemble before you grind it. Put some white gease on the tang or inside the slot to see if it rubs off on the matching part.
Ken |
Allan |
Dec 31 2004, 04:22 PM
Already done. I am hoping I still have enough length on this thing to work. I don't know why they say to grind it down. I measured the stock pump from the case mating surface to the end of the tang was almost identical to the new one.
Lo-Fi Version | Time is now: 29th April 2024 - 01:41 PM |
