Left Door Jamb Paint Code Sticker, For Late 73's and Up |
gcrotvik |
Dec 31 2013, 07:56 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I am trying to duplicate the paint code sticker that goes in the left door jamb for my 74 restoration project (paint code L80E). I am having a problem trying to determine the actual size of the sticker itself. Does anyone have a car that still has the paint code sticker in the left door jamb? If so, could you provide some measurements of the actual size of the sticker as well as the font height?
See the links below for reference. https://bowlsby.net/914/Classic/zPLM_B1B.jpg https://bowlsby.net/914/Classic/zPLM_B1C.jpg https://bowlsby.net/914/Classic/zPLM_B1D.jpg Thank you in advance for your help. Regards, Greg |
tod914 |
Jan 11 2014, 09:28 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Greg, like I suggested earlier, have your brother bring them both into photoshop. Your working layer and the original. You won't be guessing about spacing, size and kerning. And, you'll save yourself a lot of time. Labels are looking real nice!
I did this real quick test in Photoshop so you get the idea about aligning the text. The bottom layer I had to adjust the perspective on. With the correct font, you should be able to replicate it perfectly. This took about 10 minutes. |
gcrotvik |
Jan 12 2014, 03:02 PM
Greg, like I suggested earlier, have your brother bring them both into photoshop. Your working layer and the original. You won't be guessing about spacing, size and kerning. And, you'll save yourself a lot of time. Labels are looking real nice! I did this real quick test in Photoshop so you get the idea about aligning the text. The bottom layer I had to adjust the perspective on. With the correct font, you should be able to replicate it perfectly. This took about 10 minutes. Hi Tod, I worked with my brother today on fonts. He found a font that's a 95% match. Now that he has a font, he will pull the label into Illustrator to perfect the spacing and kerning. The only thing we will be missing is the small tail on the lower case a. I will have a PDF sample later this week. I need some feedback regarding the size and corners on the label used in my pictures above. They are 28 x 75 mm. I would prefer to use a stock label rather than have custom labels made. Your thoughts? Greg |
Lo-Fi Version | Time is now: 26th May 2024 - 07:00 AM |
