5 lug "cookie cutter" sizes, Wondering if there are "cookie cutters" that fit non flared cars |
david63 |
Jan 2 2014, 09:58 PM
Member Group: Members Posts: 96 Joined: 9-August 09 From: Parker Colorado Member No.: 10,653 Region Association: Rocky Mountains |
Wondering about the 5 lug "cookie cutter" sizes. Only seen 7 inch and would like to know if other sizes are available. Will the 7 inch fit under a non flared 914-6?
jimkelly |
Jan 2 2014, 10:07 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I think 7's may fit depending on tire size used but 15x6's will fit better on narrow body car.
that said 15x6 is not much wider than 4 lug 15x5.5. two of my favorite pics of an orange-ish narrow body 914s with cookies. Attached image(s) |
TomR |
Jan 2 2014, 10:13 PM
Newbie Group: Members Posts: 27 Joined: 29-August 10 From: delaware Member No.: 12,117 Region Association: None |
I've got a '73 narrow body. I'm running 15x7 cookie cutters. Tires are 205/50/70Rs. They fit perfect.
david63 |
Jan 2 2014, 11:48 PM
I've got a '73 narrow body. I'm running 15x7 cookie cutters. Tires are 205/50/70Rs. They fit perfect. I know they are not as desirable as the Fuchs but for some reason I like them. Are they OK for AutoX rims (not DE's, just AutoX)? Thinking about getting a set of 15 x 7 |
carr914 |
Jan 3 2014, 03:26 AM
Racer from Birth Group: Members Posts: 118,841 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Cookies look great on a 914!
02loftsmoor |
Jan 3 2014, 08:05 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
CptTripps |
Jan 3 2014, 09:14 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I believe mine are 15X8....and they fit on my 75' non-flared body just fine.
(I'm actually going to sell them after I'm done with my project.) |
brant |
Jan 3 2014, 09:23 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
factory produced there were only 6's and 7's..
(8's would have to be custom made after the fact) I've always preferred the 6's a very good looking wheel and always fits under stock fenders the 7's can fit, but I've had a couple of cars that they would not fit on with out pulling and massaging brant |
Jan 3 2014, 10:19 AM
The 7s are unlikely to fit in the rear of the car with 205-width rubber unless you do some fender modification. Might be as simple as mashing the fender lip flat, might be as complex as "rolling" the fenders outward. There are some 914s they do fit in, but those are the exception rather than the rule. (You gotta love semi-handbuilt cars.)
Cookies are just fine for autoX or DE wheels. They're cheap and not that heavy. The Fuchs are generally lighter in the same sizes, because they are forged instead of cast, and they tend to be stronger. That's why they are better regarded and usually cost more. But there's nothing wrong with the Cookies, especially if you inspect them for cracks before you get them. --DD |
Luke M |
Jan 3 2014, 10:31 AM
Senior Member Group: Members Posts: 1,373 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I've had a set of 6 x 15 cookie cutters on my 70 914 with 205-50-15 all around.
I never had a problem with them rubbing anywhere. I drove the car hard at autox's and track events w/o any issues. I also temporarily put them on my 6 ( did not drive the car ) and fit fine. Both cars are narrow body as well. |
Jan 3 2014, 12:26 PM
Resident German Group: Admin Posts: 41,659 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
factory produced there were only 6's and 7's.. (IMG:style_emoticons/default/agree.gif) Only 6x15 and 7x15 from the factory, anything other is custom. The 7" can be made to fit under the stock rear with some creative pulling of the fender. (IMG:style_emoticons/default/smile.gif) |
SLITS |
Jan 3 2014, 02:22 PM
I run 15 X7 with 185/65/15. A little close on the driver's rear, but no problems at all and my speedo is dead on (checked with GPS).
No, I don't need a wider tire on the /6. |
Jan 3 2014, 08:16 PM
185s on 7" wide wheels?
Your tire guys must love you... I know some that b*tched quite a lot about 195s on 7s. --DD |
JRust |
Jan 3 2014, 09:04 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Yeah get the 15x6 cookies. They work perfectly. I have a set on my 72 (IMG:style_emoticons/default/biggrin.gif)
Jan 3 2014, 09:08 PM
I know some that b*tched quite a lot about 195s on 7s. Besides me? I still think it's dangerous to stretch a tire too much ... (IMG:style_emoticons/default/shades.gif) |
914Sixer |
Jan 4 2014, 04:40 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
70-72 cars do not have the lip inside the wheel well that the 73-76. This makes using 6 & 7 inch wheels hit and miss some time depending on the tire size.
campbellcj |
Jan 4 2014, 11:47 PM
I can't Re Member Group: Members Posts: 4,546 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
The #214 car above is mine from years ago (version 2). Those were 15x7 cookies with Kuhmo 205's. They fit fine BUT the rear fenders were aggressively rolled and also pulled outward slightly. It was not really visible but was necessary for clearance.
Cookies are great wheels for the money. I think I eventually sold that set for $250 and they were pretty darn clean! (Since then I have flared the car and now have 9's with 245s in back...unfortunately the flares will not allow 275s.) |
david63 |
Jan 5 2014, 11:12 AM
Wes, this is the car that Rich Lambert turned me on to. The guy that did this conversion did it right. 3.0, factory heat exchangers, suspension mods, S brakes, lots of original 6 parts, built on a no rust 74.
For once I purchased a car that someone else spent all the money on and I was in the right place at the right time. All I have done is change out the air filters for K&N's. I love the sound and I don't drive the car in bad weather (dust storms, etc). The only things I am looking at down the road are installing a front oil cooler, do a couple of gauge mods and send the radio in to have it updated for ipod, etc. The reason for this post is because I am considering a set of 15 x 6 cookie cutters to put some R compound tires on for AutoXing. I want to leave the 15 x 6 Fuchs alone. They are perfect and have good street tires on them. I posted a bunch of pictures, forgive the spots on the lens on a couple of them. David63 any pictures to post?? I'd like to see your set up I've got a '73 narrow body. I'm running 15x7 cookie cutters. Tires are 205/50/70Rs. They fit perfect. Attached thumbnail(s) |
SLITS |
Jan 5 2014, 09:18 PM
I know some that b*tched quite a lot about 195s on 7s. Besides me? I still think it's dangerous to stretch a tire too much ... (IMG:style_emoticons/default/shades.gif) Tread width on the tires is 7" ... no stretch |
Lo-Fi Version | Time is now: 28th May 2024 - 04:37 PM |
