Headlight switch removal, is there a trick? |
malcolm2 |
Jan 3 2014, 03:21 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I am ready to wire my fogs... early fogs on a late car that did not come with fogs, I don't want to remove my knee pad and seat and twist and turn on my head under the dash. So I figured I would take the HL switch loose and let it hang. Then wire the fog switch and re-install the HL and install the Fog switch.
Does the pull portion come off? There is a collar on the dash side of the switch that threads in to tighten up, but does not seem to be much help in removing the switch. What's the trick? Clark |
Lo-Fi Version | Time is now: 29th May 2024 - 09:44 AM |
