| Elliot Cannon |
Jan 6 2014, 05:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
After getting my heads rebuilt I am Finally getting around to putting my engine back together. Can anyone recommend a good (easy) way to clean the carbon deposits off the heads? Can this be done OK without removing the cylinders?
Elliot Cannon Cleaning carbon Jan 6 2014, 05:28 PM
SLITS Put it back together ... fire it up and pour a cup... Jan 6 2014, 05:57 PM
r_towle
Put it back together ... fire it up and pour a cu... Jan 6 2014, 06:34 PM
Elliot Cannon
Put it back together ... fire it up and pour a cu... Jan 6 2014, 08:23 PM
jeffdon
Put it back together ... fire it up and pour a c... Jan 6 2014, 09:37 PM
jimkelly is oven cleaner NOT safe ? Jan 6 2014, 06:29 PM
76-914 :agree: w/ Schlitz. squirting it in with a bottle ... Jan 6 2014, 07:24 PM
Elliot Cannon
:agree: w/ Schlitz. squirting it in with a bottle... Jan 6 2014, 08:20 PM
yeahmag Water does work, but a squirt bottle works better.... Jan 6 2014, 08:32 PM
r_towle High pressure steam cleaning.
Google it, it has wo... Jan 6 2014, 08:37 PM
euro911 We use to de-carbonize using water while on a dyno... Jan 6 2014, 08:43 PM
SLITS
We use to de-carbonize using water while on a dyn... Jan 6 2014, 08:55 PM
r_towle My concern with any type of wire wheel is all my w... Jan 6 2014, 09:00 PM
StratPlayer http://www.orisonmarketing.com/pistonkleen.html Jan 6 2014, 09:06 PM
SLITS Ok Av8tor .... The water hitting the hot cylinder ... Jan 6 2014, 09:47 PM
McMark Why bother? Or are you planning on tearing down t... Jan 7 2014, 01:34 AM
Elliot Cannon
Why bother? Or are you planning on tearing down ... Jan 7 2014, 02:12 AM
ConeDodger
Why bother? Or are you planning on tearing down... Jan 7 2014, 06:58 AM
Mark Henry As a builder I've never liked the water trick.... Jan 7 2014, 09:29 AM
Matt Romanowski McMark is right. If you're not taking it all t... Jan 7 2014, 09:38 AM
Bartlett 914 While you are in there,do clean what will easily c... Jan 7 2014, 09:59 AM
ruby914 http://www.ppg.com/coatings/aerospace/coat...bon_R... Feb 6 2014, 08:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:52 AM |
