Help Identify These Combo Gauges, Sorting thru parts to sell and these are different |
jcd914 |
Jan 8 2014, 02:31 AM
I have 2 different combo fuel/temp gauges and I don't what the 2 come from originally?
This first one looks older and has a light that can illuminate the far end of the temp red zone, never seen one with a warning light in it? This second one looks newer and more what I expected, no warning light in the temp gauge. I expect the first one is from a 911 but I don't recall any of the 911s having a warning light in the red zone of the temp gauge. Jim |
GulleyGulley |
Jan 8 2014, 06:06 AM
Member Group: Members Posts: 67 Joined: 12-March 12 From: CNY Member No.: 14,243 Region Association: None |
Top one looks like a 914-6 gauge. Check the part number on the top of the gauge face
type47 |
Jan 8 2014, 07:01 AM
Top one looks like a 914-6 gauge. (IMG:style_emoticons/default/agree.gif) The one in the bottom pic is for a '73 with similar "silver button" gauges (speedo and tach). These were installed in 2L cars without a console. There are 2 more versions of the combo gauge with oil temp: one for '74 car (on "silver button") with a large red temp scale (large like the one in your pic) and '74-> with a small red temp, again, installed in cars w/o console. Pics of the gauges can be found under their part numbers in the Parts Vault on this site (The 914 Forums->Originality and History->Parts Vault). Each gauge has an oil pressure warning light, alternator light and brake light. I believe the extra "light" on the-6 gauge is for something to do with Sportomatic transmission and the extra on the -4 gauge is not used. |
Cairo94507 |
Jan 8 2014, 08:26 AM
Michael Group: Members Posts: 9,791 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
The top one looks like the gauge in my Six. Assuming mine is original, and I believe it is, that is a Six gauge.
JStroud |
Jan 8 2014, 09:16 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Well that sucks Jim, if it would have been from a 911 it would be worth less (IMG:style_emoticons/default/beer.gif)
Jeff |
Jan 8 2014, 09:49 AM
The 911 gauges are meant to be vertical, not horizontal. The printing shows that none of these are from a 911.
I doubt that the yellow at the right end of the top temp gauge is actually for a light--turn the gauge around and look. If there is no socket behind that section, there is no light there. --DD |
ConeDodger |
Jan 8 2014, 09:58 AM
Apex killer! Group: Members Posts: 23,601 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The top one is indeed identical to McMark's 914-6 combo gauge that I have sitting on my desk.
jcd914 |
Jan 8 2014, 10:02 AM
The 911 gauges are meant to be vertical, not horizontal. The printing shows that none of these are from a 911. I doubt that the yellow at the right end of the top temp gauge is actually for a light--turn the gauge around and look. If there is no socket behind that section, there is no light there. --DD Actually there is a socket for a light for that yellow section, just like the sockets for the other warning lights but different than the illumination sockets. Jim |
jcd914 |
Jan 8 2014, 10:03 AM
ConeDodger |
Jan 8 2014, 10:07 AM
The top one is indeed identical to McMark's 914-6 combo gauge that I have sitting on my desk. Does his 916/6 gauge have the warning light socket at the right end of the temp range? Jim Yes. I'm about to leave for work or I'd take a picture... At the top front of the gauge, under the glass it should have a part number. This one is 914 541 101 10 They are of course rare and valuable, though that one looks like it could use a little lovin'... (IMG:style_emoticons/default/sad.gif) |
toolguy |
Jan 8 2014, 10:20 AM
Senior Member Group: Members Posts: 1,269 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
The yellow bulb socket on the right side of the 914-6 gage is for the Sportomatic warning light. . Yeah I know, never made but that is what was suppose to go in there. .
ConeDodger |
Jan 8 2014, 10:23 AM
The yellow bulb socket on the right side of the 914-6 gage is for the Sportomatic warning light. . Yeah I know, never made but that is what was suppose to go in there. . Yes, but you'd want to know if you were about to be attacked by a Sportomatic wouldn't you? (IMG:style_emoticons/default/lol-2.gif) |
type47 |
Jan 8 2014, 10:28 AM
Jan 8 2014, 04:42 PM
At least 25 regular series-production Sportos were made...
--DD |
mrholland2 |
Jan 8 2014, 06:22 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
914Sixer |
Jan 8 2014, 07:49 PM
914 Guru Group: Members Posts: 8,893 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All you have to do is tilt the gauge down and read the part numbers in the 12 o'clock position. The part numbers will tell you all you need to know.
jcd914 |
Jan 8 2014, 08:18 PM
All you have to do is tilt the gauge down and read the part numbers in the 12 o'clock position. The part numbers will tell you all you need to know. Yes I figured that out but even tilted I can barely see the numbers on this, seems to be recessed farther that the other gauge I have. It is a 914 641 101 10, so 70/71 914/6 gauge. Did all of these have the warning light for the Sportomatic or just some? The other I have is 914 641 101 30, so 73 914/4 without Center console. Thanks Jim |
Steve |
Jan 8 2014, 08:35 PM
914 Guru Group: Members Posts: 5,597 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
At least 25 regular series-production Sportos were made... --DD Has anyone seen a real life sportomatic?? Yes about 25 years ago for sale at the Parts Heaven swap meet for less than $20k. It's now part of George's collection at AA. |
Jan 8 2014, 11:49 PM
Is that what happened to that silver one? I wish I'd taken pictures of it...
--DD |
Steve |
Jan 9 2014, 10:00 AM
Is that what happened to that silver one? I wish I'd taken pictures of it... --DD http://www.autoatlanta.com/life/showcase/ It's the orange one in George's museum. See above link. |
Lo-Fi Version | Time is now: 27th May 2024 - 02:46 PM |
