Ignition upgrades??, DIS or Billet Dizzy |
Mueller |
May 27 2003, 11:53 AM
Anyone do a cost comparison between the two if one goes all out with the MSD dizzy and components needed along with it?
The DIS (distributorless Ignition System) such as the Electromotive are pricy as well. I was shocked (no pun) to see that Holley also sells an Universal DIS for a price close to 1K...and you still need a few more hundred dollars of parts and fabrication!!!!! I'll need something that also has ignition retard which I believe the MSD offers as an added part. This post has been edited by Mueller: May 27 2003, 11:54 AM |
Mark Henry |
May 27 2003, 12:25 PM
Wow, for about 1K I'm getting my SDS PEFI and it comes with programable DIS dual coil ignition!
(IMG:style_emoticons/default/driving.gif) |
MJHanna |
May 27 2003, 12:28 PM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
You have a ton of options with the MSD, all of it plugs in together. Get the distributor, plug it into a 6 AL for the rev limiter and add the timing retard. You use the “Boost Timing Master” if you run a blower or turbo as it automatically retards the timing as your boost increases.
Demick |
May 27 2003, 12:33 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
What do you need the retard for? You don't have to pass smog, so you shouldn't really need the retard (unless your turbo requires it - I know next to nothing about turbos).
Demick |
Mark Henry |
May 27 2003, 12:40 PM
QUOTE(Demick @ May 27 2003, 10:33 AM) What do you need the retard for? You don't have to pass smog, so you shouldn't really need the retard (unless your turbo requires it - I know next to nothing about turbos). Demick Yeh, the turbo needs it. Some of the guys on the STF have done a low budget retarded dizzy I think. |
Mueller |
May 27 2003, 06:12 PM
Ouch......
I just figured out the MSD would cost a small fortune.. MSD Billet Alum dizzy=200 MSD Multi-spark box with boost retard=300 Spark Plug wires for billet Dizzy=50 Coil=35 total=585.00 time to look at other, cheaper options (IMG:style_emoticons/default/smile.gif) |
ChrisReale |
May 27 2003, 06:19 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
I thought the whole Idea was to spend as much money as possible while your car is still on jack stands...at least thats what they told me (IMG:style_emoticons/default/tongue.gif)
Lo-Fi Version | Time is now: 3rd May 2024 - 11:54 AM |
