Ignition upgrades??, DIS or Billet Dizzy |
Mueller |
May 27 2003, 11:53 AM
Anyone do a cost comparison between the two if one goes all out with the MSD dizzy and components needed along with it?
The DIS (distributorless Ignition System) such as the Electromotive are pricy as well. I was shocked (no pun) to see that Holley also sells an Universal DIS for a price close to 1K...and you still need a few more hundred dollars of parts and fabrication!!!!! I'll need something that also has ignition retard which I believe the MSD offers as an added part. This post has been edited by Mueller: May 27 2003, 11:54 AM |
MJHanna |
May 27 2003, 12:28 PM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
You have a ton of options with the MSD, all of it plugs in together. Get the distributor, plug it into a 6 AL for the rev limiter and add the timing retard. You use the “Boost Timing Master” if you run a blower or turbo as it automatically retards the timing as your boost increases.
Lo-Fi Version | Time is now: 17th May 2024 - 11:13 PM |
