Steering wheel hard in turns, Update: The solution was alignment |
ndfrigi |
Jan 15 2014, 01:43 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi, Can I get some suggestions/comments on how can I improve my steering wheel during turns.
Currently my front tires are 185x65x15. Front wheels looks very straight facing the car from front view, No issue or force to left or right when driving straight. Pretty much no issue also when running 65 to 85 mph (offcourse I only drive more than 65mph when I just follow the flow of the traffic here in California). Do I need to remove the steering rack for complete clean up or re-greasing? Thank you in advance and God Bless! Noel |
Dave_Darling |
Jan 15 2014, 01:51 PM
The joints in the steering column could be binding up. We have seen that, particularly if the steering system has been worked on recently.
Evidently you can loosen the bolts that hold the universal joints onto the steering column pieces, and move them just a little bit. Tighten the bolts and see if that helps. Another possibility is that you have too much caster angle. --DD |
ndfrigi |
Jan 15 2014, 02:47 PM
The joints in the steering column could be binding up. We have seen that, particularly if the steering system has been worked on recently. Evidently you can loosen the bolts that hold the universal joints onto the steering column pieces, and move them just a little bit. Tighten the bolts and see if that helps. Another possibility is that you have too much caster angle. --DD Thanks a lot Dave for responding! On this pictures of right and left top struts, do you think sir this might be the reason? The passenger side strut is not installed in the middle compare to the driver side. |
yeahmag |
Jan 15 2014, 04:17 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
At the very least you need an alignment!
ThePaintedMan |
Jan 15 2014, 04:30 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
At the very least you need an alignment! (IMG:style_emoticons/default/agree.gif) There is usually a small amount of caster difference when a car is aligned properly for the street to account for the crown of the road. But looking at that picture - things do not look right. |
ndfrigi |
Jan 15 2014, 04:32 PM
Dave thanks again! I tried to straighten the passenger side strut and it did made a big difference now. I will also bring it to allignment soon after replacing the tie rod with turbo tie rod.
ndfrigi |
Jan 15 2014, 04:49 PM
Thanks also Aaron and George!
Madswede |
Jan 16 2014, 01:26 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
And here I was all ready to be an ass and say, "You DO know it doesn't have power steering, right??"
But I see it's a legit issue, I just misread the thread title, so I'm not gonna say it. Oh wait, I did. Now I'm a (IMG:style_emoticons/default/burro.gif) |
ndfrigi |
Jan 22 2015, 12:25 PM
Totally forgot this thread already. Well the only issue only was the alignment. I did manual alignment and now the steering has improve a lot. Maybe after doing the 5 lug conversion and replacement of turbo tie rod, I will have it align in a good shop.
Thanks again! |
SirAndy |
Jan 22 2015, 12:33 PM
Resident German Group: Admin Posts: 41,670 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
A good professional 4 wheel alignment can do wonders for your car ...
(IMG:style_emoticons/default/shades.gif) |
ndfrigi |
Jan 22 2015, 12:41 PM
A good professional 4 wheel alignment can do wonders for your car ... (IMG:style_emoticons/default/shades.gif) Thank you SirAndy! |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:34 PM |
