shift rod tubing |
shift rod tubing |
partwerks |
Jan 16 2014, 10:51 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
What is the I.D. of the shift rod tube, and the O.D. of the steering wheel shaft with the U Joints? I'm wondering about the fitment of the steering shaft with the splined ends and U Joints if they will fit into it??
Mike Bellis |
Jan 16 2014, 11:50 PM
When I built my shifter, I used 3/4" DOM tubing, .120 wall. Plenty strong. The OD of the front shift rod is close to 3/4". I bought some 3/4" U Joints from ebay and welded, drilled and tapped various connection points. I re-used the front splined piece from the front rod. I bought 2 bronze console bushings and built a carrier for the rear shift pivot. I also bought a spherical bulkhead bearing bearing for the firewall.
partwerks |
Jan 17 2014, 06:26 AM
When I built my shifter, I used 3/4" DOM tubing, .120 wall. Plenty strong. The OD of the front shift rod is close to 3/4". I bought some 3/4" U Joints from ebay and welded, drilled and tapped various connection points. I re-used the front splined piece from the front rod. I bought 2 bronze console bushings and built a carrier for the rear shift pivot. I also bought a spherical bulkhead bearing bearing for the firewall. Do you happen to have some pictures of the setup? |
76-914 |
Jan 17 2014, 08:32 AM
It's been done.I remember someone here posted pic's of their install with the steering u-joint. (IMG:style_emoticons/default/idea.gif)
stownsen914 |
Jan 17 2014, 09:13 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
The stock shift rod is actually pretty thin wall stuff, like .060". Generally that's good enough, EXCEPT where you're going to bolt up a U joint. You actually don't want your shift rod too heavy as that can reduce feel and responsiveness in your shifting. I had to significantly reconfigure my shift linkage due to other mods on my racecar. I used thin wall stuff for the longer sections of the shift rod, and welded in short sections (1-2") of heavier wall tubing like .120" where the U joint bolts up.
Scott |
Mike Bellis |
Jan 17 2014, 09:23 AM
When I built my shifter, I used 3/4" DOM tubing, .120 wall. Plenty strong. The OD of the front shift rod is close to 3/4". I bought some 3/4" U Joints from ebay and welded, drilled and tapped various connection points. I re-used the front splined piece from the front rod. I bought 2 bronze console bushings and built a carrier for the rear shift pivot. I also bought a spherical bulkhead bearing bearing for the firewall. Do you happen to have some pictures of the setup? Its in one of my build threads. Part 1 or 2 |
partwerks |
Jan 17 2014, 06:40 PM
When I built my shifter, I used 3/4" DOM tubing, .120 wall. Plenty strong. The OD of the front shift rod is close to 3/4". I bought some 3/4" U Joints from ebay and welded, drilled and tapped various connection points. I re-used the front splined piece from the front rod. I bought 2 bronze console bushings and built a carrier for the rear shift pivot. I also bought a spherical bulkhead bearing bearing for the firewall. Do you happen to have some pictures of the setup? Its in one of my build threads. Part 1 or 2 Where do I find that at? |
Mike Bellis |
Jan 17 2014, 07:34 PM
Where do I find that at? Looks like I used 5/8" http://www.914world.com/bbs2/index.php?sho...3156&st=100 (IMG:http://www.914world.com/bbs2/uploads/post-10496-1302033770_thumb.jpg) |
Lo-Fi Version | Time is now: 17th May 2024 - 09:10 PM |
