I need someone |
I need someone |
skline |
Jan 2 2005, 03:19 PM
Ok, I took out the rear shift rod and modified it again and I still cannot shift the car into reverse. In fact, I can barely get it into any gear now. I am ready to give up on it, so I need someone to ride in the trunk and shift it for me manually. We could cut a hole in the trunk and you can just reach your arm down and shift it each time you hear the clutch engage. Does that sound like something someone here wants to do? Other wise, I have another stock rod I will cut and modify to try to make this thing work. (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Eric_Shea |
Jan 2 2005, 03:21 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'm game... can I get a burger outta the deal? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
soloracer |
Jan 2 2005, 03:22 PM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
Are you taking applicants for the job? In addition to the oil tank does your car have a beer tank? I have a feeling that if one of us was to "assume the position" you would be getting 1 beer per mile so it could make driving the teener a tad expensive. (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif)
McMark |
Jan 2 2005, 03:23 PM
Whoa whoa whoa. There's burgers involved? Nobody told me that.
Aaron Cox |
Jan 2 2005, 03:25 PM
WTF did you do?????
why not take a stock rod, and ADD a length of rod EXACTLY the distance the trans was moved back..... Easy (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
ws91420 |
Jan 2 2005, 03:26 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
Why not get Britney? (had to say it)
skline |
Jan 2 2005, 03:29 PM
I did that already. Then when Jared and I pulled the trans out and put it back in, the distance changed. So I went back in and cut it again and set it to the exact length per Renegade instructions, It is now worse than it was before. So I guess I will start over with a fresh rod and make it 1.25 inches longer than stock.
ejm |
Jan 2 2005, 03:31 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Sounds like you could use a Trunk Monkey (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Aaron Cox |
Jan 2 2005, 03:44 PM
you can make up for the change at the shifter console. it has a slip joint. Side to Side adjustment is done there, as is Front to Back adjustment (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) read your haynes manual (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) let me know if you need further clarification |
Aaron Cox |
Jan 2 2005, 03:53 PM
is the rod not traveling far enough fore to aft? or not enough side to side to engage gears correctly?
ex: i can hit gears 1 , 3 , 5 and not R,2,4, or i can hit R and 1 |
skline |
Jan 2 2005, 04:16 PM
I cant hit reverse, 2, 4. It doesnt feel right at all. I have limited movement of the shifter side to side and fore to aft. Has anyone ever just straightened out one of these rods? I think part of my problem is it is hitting on the engine mount bar. If I straighten it out, it will make it longer and it may not hit the bar. Doesnt look like it will be that easy to make it straight however. I was just wondering if anyone has done this.
iamchappy |
Jan 2 2005, 04:43 PM
Everyone seems to have there method of adjusting the shift rod, My method is I drive around with access to the shift rod coupler and a few wrenches. I drive around starting and stopping, and adjusting until everything feels perfect. When you have it right you will know. A good initial setting is put it into 3rd loosen up the coupler move the shift into the neutral area and over a little to the right and retighten.
You will be able to feel when the spring lockout into reverse is separating the reverse and 2nd gear selection. |
Aaron Cox |
Jan 2 2005, 05:03 PM
scott... this is way easy.
make a bar that doesnt hit the engine bar.... then well go from there. you can manually set the trans in 2nd gear, and with the rod loose at the shifter...set THE SHIFTER where you want 2nd gear to be. Tighten the clamp inthe tunnel. then go fore aft/ side side movements from there. if you cant hit a gear, roate the shift rod in the tunnel a tad until you can.... this aint rocket science, you should have it done in an hour or two (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) once you get it there use the above imchappy method to check |
Elliot_Cannon |
Jan 2 2005, 06:42 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
How can the distance change just by removing and replacing the transmission? I'll be home tomorrow afternoon I think and maybe can come over and help. Let me know if you are working on the car tomorrow. Cheers, Elliot |
skline |
Jan 2 2005, 07:04 PM
Yeah, I will be out here tomorrow afternoon. Got a few jobs in the morning first. I have to try to get the Christmas lights down now so I stopped working on the car.
rick 918-S |
Jan 2 2005, 07:17 PM
Hey nice rack! -Celette Group: Members Posts: 20,504 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Broke a throttle cable once on a corvair. I had the wife drive while I sat under the engine lid and ran the throttle! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) pretty dumb now that I think back on it.
skline |
Jan 2 2005, 07:44 PM
Desperate times call for desperate measures. It just shows that you are willing to do what it takes. |
Joe Bob |
Jan 2 2005, 08:18 PM
You need a rack to put it up on while "Dumb" is in the driver seat....."Dumber" underneath....adjustments can be made whilst under the car.....
I have a rack...c'mon up, we'll fix it. Signed Dumb.... (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) PS Dumber is only a 1/2 mile away and works fer beer.... (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
skline |
Jan 2 2005, 10:28 PM
I do need that trailer Mike, seems it will be the only way this car ever goes anywhere. I will send you a PM
DJsRepS |
Jan 3 2005, 07:24 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
My car had simular shifting problems with these bushings in there in order pvc shifter ball, bushing by shifter, bushing in firewall, (I hope there never is a fire!) and the rear pvc bushing clamped to the bar. Reverse and 1,2,3rd all great but hard as hell to find 4th&5th. All better now thanks to Pelican. These were only 6yrs old. I think we are getting 30yr old new parts. My new set was so stiff and hard to get in, I even hard boiled them. How are all of yours?
Lo-Fi Version | Time is now: 17th June 2024 - 02:34 AM |
