Helper Spring - Floater/Slider Use, aka - take-up spring but NOT a tender spring, got it? :o) |
tomeric914 |
Jan 18 2014, 03:28 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Finally got all of my parts together for the new coilover setup and ran into a little snag. For giggles, I purchased a floater/slider to go with each helper spring to keep everything aligned, but on trial fitment, I notice that the slider hits the adjustment collar before the helper is fully compressed (IMG:style_emoticons/default/dry.gif) . There is no way that is correct (see below) and this will fail over time.
A floater isn't really needed, so it could be run without one or part of the floater sleeve could be removed to eliminate the interference. Anyone else run into this? |
Matt Romanowski |
Jan 18 2014, 08:24 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
The zero rate helper spring goes on top of the regular spring with the divider in the middle. It won't ever reach the perch.
tomeric914 |
Jan 18 2014, 08:39 PM
The zero rate helper spring goes on top of the regular spring with the divider in the middle. It won't ever reach the perch. Then it will conflict with the upper perch and potentially move all over the place. I'll shave off part of the floater/slider. If this were a tender spring, the slider would never touch. Reality is that the slider really isn't needed with a helper spring. It was suggested by the supplier I bought the coilover parts from. I'll shave it and put together an assembly thread, FWIW. |
tomeric914 |
Jan 22 2014, 01:57 PM
I called Hypercoil today to see what their suggestion was for helper spring couplers and was able to talk with their Product Development Manager. He said that a divider was always necessary when 2 springs are stacked on top of each other and suggested their 18DS100 which is a plastic stacked spring divider. He said that even though the spring divider will hit the perch before the helper spring fully compresses, a 200 lb spring (in my case) would work fine with it. He also mentioned that Hypercoil will be coming out with a new thicker helper spring (CS650) in about 6 weeks. This helper spring will address the divider problem that I illustrated above.
I shaved the red dividers down shown above, but they still contact the threaded collars before the helpers are fully compressed. Shaved down. they also don't slide as well, but their movement should only be at the extreme limits of suspension travel. It's well below zero and will be snowy for at least the next 6 weeks anyway. Maybe I'll just wait... |
914werke |
Jan 24 2014, 06:14 PM
"I got blisters on me fingers" Group: Members Posts: 10,045 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I made a pair of these these today. (IMG:style_emoticons/default/smile.gif) The center opening easily clears the top mount when compressed. Recessed both sides.
Attached thumbnail(s) |
tomeric914 |
Jan 24 2014, 06:37 PM
I made a pair of these these today. (IMG:style_emoticons/default/smile.gif) The center opening easily clears the top mount when compressed. Recessed both sides. Now you're just teasing me... Are these in your garage sale??? (IMG:style_emoticons/default/beerchug.gif) |
tomeric914 |
Jan 25 2014, 11:15 PM
Lo-Fi Version | Time is now: 6th May 2024 - 07:05 PM |
