> Helper Spring - Floater/Slider Use, aka - take-up spring but NOT a tender spring, got it? :o)
tomeric914
post Jan 18 2014, 03:28 PM
One Lap of America in a 914!
Finally got all of my parts together for the new coilover setup and ran into a little snag. For giggles, I purchased a floater/slider to go with each helper spring to keep everything aligned, but on trial fitment, I notice that the slider hits the adjustment collar before the helper is fully compressed (IMG:style_emoticons/default/dry.gif) . There is no way that is correct (see below) and this will fail over time.
A floater isn't really needed, so it could be run without one or part of the floater sleeve could be removed to eliminate the interference. Anyone else run into this?
Matt Romanowski
post Jan 18 2014, 08:24 PM
The zero rate helper spring goes on top of the regular spring with the divider in the middle. It won't ever reach the perch.
tomeric914
post Jan 18 2014, 08:39 PM
QUOTE(Matt Romanowski @ Jan 18 2014, 09:24 PM) *
Then it will conflict with the upper perch and potentially move all over the place. I'll shave off part of the floater/slider.
If this were a tender spring, the slider would never touch. Reality is that the slider really isn't needed with a helper spring. It was suggested by the supplier I bought the coilover parts from. I'll shave it and put together an assembly thread, FWIW.
tomeric914
post Jan 22 2014, 01:57 PM
I called Hypercoil today to see what their suggestion was for helper spring couplers and was able to talk with their Product Development Manager. He said that a divider was always necessary when 2 springs are stacked on top of each other and suggested their 18DS100 which is a plastic stacked spring divider. He said that even though the spring divider will hit the perch before the helper spring fully compresses, a 200 lb spring (in my case) would work fine with it. He also mentioned that Hypercoil will be coming out with a new thicker helper spring (CS650) in about 6 weeks. This helper spring will address the divider problem that I illustrated above.
I shaved the red dividers down shown above, but they still contact the threaded collars before the helpers are fully compressed. Shaved down. they also don't slide as well, but their movement should only be at the extreme limits of suspension travel. It's well below zero and will be snowy for at least the next 6 weeks anyway. Maybe I'll just wait...
914werke
post Jan 24 2014, 06:14 PM
I made a pair of these these today. (IMG:style_emoticons/default/smile.gif) The center opening easily clears the top mount when compressed. Recessed both sides.
tomeric914
post Jan 24 2014, 06:37 PM
QUOTE(rdauenhauer @ Jan 24 2014, 07:14 PM) *
Now you're just teasing me... Are these in your garage sale??? (IMG:style_emoticons/default/beerchug.gif)
tomeric914
post Jan 25 2014, 11:15 PM
Link to my "How To" video and parts list:
http://www.914world.com/bbs2/index.php?showtopic=229288
- Lo-Fi Version Time is now: 28th May 2024 - 09:14 AM
